Question about HP Computers & Internet
I have an hp 2000-2b09wm i was trying to take of the keyboard but i pulled to hard and the zif connector cover broke and i lost that piece so where can i buy another on or how can i put my keyboard without
  • HP Master
  • 16,408 Answers
You are going to have to replace the motherboard.
Posted on Feb 10, 2014
3 Suggested Answers
  • 105 Answers
SOURCE: Broken Touchpad ZIF Connector
Best bet is to obtain a faulty motherboard and use the clip from that - they are often sold very cheaply declared as faulty on ebay.
Please rate my assistance I hope it is helpful.
Posted on Mar 23, 2008
  • 163 Answers
SOURCE: HP Pavillion DV5 laptop - broken zif connector
Can you lift the plastic bar at either side on the board where the cable was pulled from?.If so,just lift both sides,one at a time till the plastic bar is loose,then seat your cable straight down until it will go no further and then push both sides of the bar back down to secure the cable...hope that fixes your problem:)
Posted on Apr 12, 2010
I have an hp 2000-2b09wm i was trying to take of the keyboard but i pulled to hard and the zif connector broke where can i buy another on or how can i fix it
You can get a keyboard plus cable for $34 from http://www.cheaplaptopkeyboards.com/hp-2000-2b09wm-keyboard.html It gives you step by step instructions.
Or the individual parts from http://www.donconnex.com.tw/product-m.htm
Feb 10, 2014 | HP Computers & Internet
Removing the keyboard broke the plug
Never have seen a Keyboard's Flat Flex Cable, that had a connector on the motherboard end. http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The motherboard connector is a type of ZIF connector. Zero Insertion Force. It is composed of TWO pieces, but DOES NOT come completely apart.
The bottom piece is the BODY. The top small piece is the Locking Bar.
IF, the Locking Bar is broken off, you may be looking at MOTHERBOARD REPLACEMENT.
http://www.laptoprepair101.com/laptop/2009/11/17/fix-broken-keyboard-connector-on-laptop-motherboard/
Regards, joecoolvette
Aug 31, 2012 | Acer Aspire One D270-1824 Aod270-26dkk
Tx2 keyboard zif connector broken
Hello i ran into this problem twice with a Toshiba and a hp what i did was go through my parts found an old laptop keyboard and cut the ribbon cable from that folded it over to make it twice as thick and worked it into the groove then i slid a piece of credit card into the middle of the folded cable like a sandwich the credit card shim was the meat and the folded ribbon cable shim the bread put a piece of tape on top to keep it secure never a problem take a breath think about it and dont use force or glue the mind is a powerful thing use it this does not mean mother board replacement
Jul 19, 2012 | HEWLETT-PACKARD HP Touchsmart TX2...
How do I remove/replace the keyboard from a HP Pavillion dv7-2277cl
1. Remove 6 screws from the bottom of the case (as shown). These screws hold the accessory cover.
2. Remove one screw securing the CD/DVD drive. Slide the CD/DVD drive to the left to disconnect it from the motherboard. Remove the CD/DVD drive.
3. Remove all marked screws from the bottom of the notebook.
The yellow circled screws secure the keyboard cover, and the green one secures the HP Pavilion DV7 keyboard.
4. Turn the computer display-side up and open it as far as possible. Insert a guitar pick or small flat screwdriver between the keyboard cover and case and slowly move along the side.
5. Lift the keyboard cover. Be careful, it's still connected to the motherboard. Release the zero insertion force (ZIF) connector and disconnect the cable from the LED board. Remove the keyboard cover.
6. Remove the four screws that secure the HP Pavilion DV7 keyboard.
7. Lift the rear edge of the HP Pavilion DV7 keyboard until it rests at an angle. Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover and rest it on the display.
8. Release the ZIF connector to which the keyboard cable is attached and disconnect the keyboard cable. Remove the HP Pavilion DV7 keyboard.
You can refer to the complete article via the link below:
http://laptoppartstore.weebly.com/replace--remove-hp-pavilion-dv7-keyboard.html
Apr 08, 2012 | HP Pavilion dv7 Keyboard (483275-001)
New to get instructions for replacing Black Keyboard for Hp Probook 4510s Series laptop.
Here is a pdf site manual for that.(but this is site is kind a slow in loading)
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01905586/c01905586.pdf
Here is a video tutorial on how to replace a hp probook keyboard (But this is for 4710 model, i think you can get some ideas from here)
And finally if this all doesnt help you here is a site containg instructions on how to replace your keyboard .
http://www.sparepartswarehouse.com/blog/post/how-to-replace-the-keyboard-on-the-hp-probook-4510.aspx
hope I helped you, please rate my solution thanks.
Jun 30, 2011 | HP Computers & Internet
Hp g60-630us how to remove keyboard
1) Remove ALL electrical sources.
AC adapter and Battery. Leave the Battery Compartment Door off.
2) Laptop closed turn it over, battery compartment facing Away from you.
3) Looking at the inside edge of the Battery Compartment that is towards you, there are 3 screws to remove.
They are right along the edge that faces you.
There is one in the middle, and one on the right side, that are down in a little indention. (A small drop in the case)
There is one to the left.
Philips head screws. Remove them, place them in a multi-compartment container, and mark the compartment for where they came from.
(DO NOT mix the screws up that you are going to remove)
4) Turn the laptop over, open it.
Carefully lift the Front of the Keyboard up to an angle. (The Front of the Keyboard faces the LCD screen)
DO NOT lift it straight up.
There are plastic tabs that protrude from the back of the Keyboard, and go into the Keyboard Cover.
(The dark rectangular shaped piece of plastic that surrounds the Keyboard, and ends at the Palm Rest, is the Keyboard Cover)
Ease the Keyboard forward towards the LCD screen. Lay it down next to the LCD screen, and on the Keyboard Cover.
You want to be able to access the Keyboard cable's connector.
The Keyboard cable connector is the white connector in the middle, with the ribbon cable leading from it to the Keyboard.
This is a ZIF connector.
The ZIF connector is made of two parts. It opens, but does NOT separate into two parts.
The white tabs you see on either side are eased towards the LCD screen.
Use your fingernails.
Push on one 'ear' a little, then go to the other side. Keep alternating back, and forth until the ZIF connector is open. It only opens up about 1/4 inch.
This action opens the ZIF connector, where the flat ribbon cable can be eased out of it.
(To reinstall, line the ribbon cable up in the connector, Insert it until it stops, then squeeze the white 'ears' towards the front of the laptop. {Towards you)
Use EXTREME care when opening, and closing the ZIF connector. If you break it you have to replace the motherboard.
Remove the Keyboard.
Regards
joecoolvette
Nov 01, 2010 | HP G60630US Notebook
How do I replace the keyboard in a HP Pavilion dv6451us laptop
To start I suggest you have a No.1, and a No.2 Philips head magnetized screwdriver, a small pair of Needlenose pliers, and a multi-compartment container for the screws.
(When working on a laptop this is the ONLY place I would advise using a magnetized screwdriver. Otherwise NO!)
There are different sized screws, and they also have different threads. It may be very easy to mix these up.
I also suggest you work on a table. If you have a carpet floor, do not swing your feet across it as you work.
(I feel required to post this, because there are those who might work on their bed, a couch, or directly on a carpet floor. These are high areas of Static electricity. Static will fry out a computers delicate hardware components in a flash! )
1.Computer off, remove all electrical sources. AC adapter, (Charger), and Battery.
2.Close the laptop. (Close the LCD screen down)
Turn the laptop upside down, front panel towards you.
Now you are going to remove the Switch Cover.
(Cover under the LCD screen, above the keyboard. Has the speakers, LED lights, Power On button, and so on)
Switch Cover Removal:
Look down in the battery compartment. With the battery removed you will now see three Philips head screws. One on each side. One in the middle.
Remove them.
Turn the laptop back over, open the LCD screen, and lay the screen back as far as it will go.
Lift the rear edge of the Switch Cover, and swing it forward until it rests on the keyboard. (The rear edge of the Switch Cover is next to the LCD screen)
[CAUTION!
Use finesse when lifting the Switch Cover, and resting it on the keyboard. There is a Small flat ribbon cable connected to the Switch Cover. You can only move the cover so far]
Notice that the small flat ribbon cable ends in a white connector towards you. This is a ZIF connector. (Zero Insertion Force) The flat ribbon cable is the LED light cable.
The ZIF connector is composed of two pieces. Think of a small rectangular box within a larger rectangular box.
The smaller inner rectangular box has a lip on it. This keeps it from going down through the larger box.
There is also a lip on the bottom of the smaller box, which keeps it from coming all the way out.
The smaller box is lifted by the top lip, or flange, to release the flat cable.
Again, it only lifts up so far.
It's hard to discern at first how the two box like parts separate from each other, your first time, hence this long explanation.
Looking close at this connector, you will see a thin parting line, approximately 1/16th of an inch down from the top.
Parting line where the two halves, or box like shapes separate.
Use your fingernails to hold the top flange, and the bottom half of the connector. Ease the connector apart. You may find placing your fingernails in the parting line helps, when you are separating the connector. Sometimes you have to gently rock the top half as you are pulling out.
Sometimes the connector top eases up with no problem. Sometimes it's stiff. Again, I advise using finesse.
The flat ribbon cable is composed of wires laid side by side, and installed into a flat ribbon like sheath of insulation. Each wire end has a conductive coating on it. When the ZIF connector is open, the flat cable slips right out.
[When installing, make sure you reinstall the flat ribbon cable in the same direction it came out. Be sure the ZIF connector is fully closed]
This particular ZIF connector may be different from the explanation above. Some do separate, and the cable is still connected to one side of the white ZIF connector.
Lay the Switch Cover aside.
3.Keyboard removal:
Close the laptop. Turn the laptop over, bottom facing you. Remove the Memory Module Compartment Door.
(Looking at the bottom of the laptop, this compartment door is in the middle. It is rectangular shaped, with the length going up, and down.
The battery compartment is above. The battery release latch button is to the upper left, of the Memory Module Compartment Door.
There are two Philips head screws. One in the upper left, and one in the upper right. (Upper is facing the battery compartment)
Remove them.
There are four screws to remove the keyboard.
Right below where the upper left screw was removed, for the memory compartment cover, is one of the screws that hold the keyboard on.
It's down in a small hole. (Below, in the statement, 'Below the upper screw that was removed', means facing you)
To the right of the memory compartment door opening is another keyboard screw. It's on the outside of the opening, down in a small hole. (Right above an air vent)
There are two more screws down in the battery compartment.
Now turn the laptop back over carefully. Open the LCD screen, lay it back as far as possible.
Lift the rear of the keyboard up to a 45 degree angle, towards you. (Rear of the keyboard is the edge towards the LCD screen. The keyboard will only lift so far due to a flat ribbon cable connected to it)
Slide the keyboard towards the LCD screen carefully. There are two tabs you are sliding out of the body of the laptop. (Top Cover)
These two tabs are on the keyboard edge facing you.
Once the tabs are clear of the slots in the Top Cover, bring the keyboard to a level position, and bring it back towards you. (It will only go so far. Flat ribbon cable!)
Lay the keyboard down on the Palm Rest.
Release the ZIF connector to which the keyboard flat ribbon cable is connected, and remove the keyboard cable from the System Board.
(Motherboard)
Reverse these steps to install the new keyboard.
In case I haven't explained these steps clear enough, come back, and let me know.
Thank you for using FixYa.
Nov 24, 2009 | HP Computers & Internet
Computer compaq nc 6000 power off during working
If you feel the power adapter working fine with the diff unit its not an issue with the adapter,
Now, if the unit is not powering on.just perform this:
Take out the batter, adapter and make the unit stand alone and press and hold the Power button with out any power to the unit(Without battery , adapter) by doing that we can take the static charge which might be causing the issue,
If that does not fix the issue, try reseating the RM if you are comfortable, here is the steps:
Primary memory board removal Before you begin: Remove the battery and keyboard.
  1. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
    Caution! When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  2. Grasp the primary memory board by the edges and pull gently to remove it.
  3. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
  4. Press the primary memory board down to latch the arms.
Steps to remove Keyboard:
eyboard removal Before you begin: Remove the battery.
  1. Loosen the captive P1 Phillips-head screw that secures the memory/Mini PCI cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the outside edge of the memory/Mini PCI cover and remove it.
  3. Remove the two T8-9 mm screws that secure the keyboard to the base enclosure.
  4. Turn the notebook right side up and open the display panel fully.
  5. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the LED switch cover.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  7. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. After ensuring that the locking bar on the keyboard ZIF connector is unlocked, place the keyboard right side up on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Toe the tabs on the bottom edge of the keyboard into the top cover.
  5. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the LED switch cover.
  6. Close the display panel and turn the notebook upside down.
  7. Replace the two T8-9 mm screws that secure the keyboard to the base enclosure.
  8. Toe the memory/Mini PCI cover into the enclosure.
  9. Tighten the captive P1 Phillips-head screw.
Jul 06, 2009 | HP Compaq nc6000 Notebook
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
May 17, 2009 | HP Computers & Internet
Have a replacement kb K000026590 a Tosh Sat M65-E821 (PSM60U-0CR021). I have no instructions as to how to be the top of the the case off - short of jimmying w/ an sdrvr. Help pleaaase!
hi this is how it is done in a HP laptop
i hope it helps you out
Remove the keyboard
  1. Loosen the four captive P1 Phillips-head screws that secure the keyboard to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  4. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board (only on models with a pointing stick). CAUTION: Use care to prevent damaging the ZIF connector and ribbon cable.
  5. Remove the pointing stick ribbon cable from the ZIF connector.
  6. Using minimal force, flip the locking bar up to unlock the keyboard ZIF connector on the system board.
All the best
AJ
Jun 05, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
