Question about AT&T ATT-974 Corded Phone
New call light on - AT&T ATT-974 Corded Phone
How do we fix a hunter fan light kit that blew a bulb and now we can not get new bulbs to light/
You might check the light limiter, a.k.a. wattage limiter. Check the manuel for the location. F you dont have one you can find one on the hunterfan.com sight. Some of the fans only support low wattage lights bulbs (candelabra light bulbs) 60 watts and lower. You might have to open the light limiter to check for burn marks. If there is you need to buy a new one. And if you cant find the lights at a store you can always find them at a online store.
Jan 01, 2015 | Hunter Dryers
Put new after market rear bumper on my 2002 chevy Silverado 2500hd and my new license plate light has one wire and old light has 2 wire so I just connected the hot wire to new light and now my rear tail...
Check for that fuse in a fuse panel under the dash.
That second wire from the old light is a ground wire, whereas the new light's socket is case grounded if there is no ground wire for the light. If the fuse for the tail lights is good, check if the tail lights lost a ground .
Aug 07, 2013 | 2006 Chevrolet Silverado 2500HD 2WD
None of my tail lights work. i changed the bulbs, tail light control board and fuses. I'm an electrician so i need a wire diagram of a 1996 chevy suburban
Your solution is a new combination switch,It also sounds like the hazard are activated and is non operation interfering with the brake light,but either way the solution is a combination swith
Jul 08, 2012 | 1996 Chevrolet Suburban
Model number ffhs2313lp3 light burnt out got a new one wont work
if you new light still didn't work . so what's the problem ? maybe the light was in good condition . did you check you circuit board ?
home light bulbs
May 31, 2012 | Frigidaire Refrigerators
I have had ongoing lamp issues. I have purchased 2 new lamps, (Phillips) The new lamp won't light, but the old original lamp will light but is dim. Why would the old lamp light and new one won't. The...
Hi, You old lamps were compromised due to long usages while the news lamps are defective. They may manufacturing defect. Please claim the new lamps to supplier then.
Regards ,Jay
Jan 28, 2011 | Panasonic PT-56LCX66 Television
3 way switch and dimmer. Switch and dimmer both turn light on and off. However dimmer does not dim the light. Dmmer had performed properly until replaced light (did not change dimmer or swith wiring only...
Please describe the old light fixture and the new light fixture. If the new light fixture is fluorescent, then using a dimmer with it won't work and is a fire hazard - unless you have a specially designed ballast which is designed to be used with a standard dimmer. If that is what you have, then the ballast in your new fixture is bad.
May 10, 2010 | Electrical Supplies
HOW TO INSTALL A EXTRA REVERSING LIGHT TO ILLUMINATE TOW BALL ON MY CARAVAN AT NIGHT.I HAVE A REVERSING CAMERA FITTED BUT IN BAD LIGHT IT IS USLESS.
connect a new light on to the same circuit as the reversing light, take the postive off the reversing light, the earth goes to ground on the new light
Aug 10, 2009 | 2009 Toyota Land Cruiser
New Fog Lights Won't Work
check fuse 19 in the fuse blocks under the hood...there is also a relay for the fog lights
Dec 24, 2008 | 2006 Jeep Wrangler
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
AT&T ATT-974 Corded Phone Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
