Question about Sunbeam Humidifier. 0.65-Gallon Warm Mist Humidifier SWM2412-UM
Full tank light is on, but tank is full - Sunbeam Humidifier. 0.65-Gallon Warm Mist Humidifier SWM2412-UM
3 year old Essick tower D46720 sat during off season. Cleaned, filled and plugged in today and will not turn on. Lights are on; nothing happens.
The red water level light was on even though both tanks were full. The white float behind the filter WAS stuck to the bottom of the tank. I just moved it to its floating position and voila! it is working.
Nov 21, 2016 | Essick Air D46720 6 Gallon Humidifier
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Ultrasonic humidifier's fan isn't running, the light indicated red instead of blue, and there is no mist coming out. How to fix it please since we cannot afford for another one right now.
I had the same problem. Looked up the manual online. Red light indicates water level is low I had just refilled the tank so that was not the problem but manual said to make sure water tank was firmly, securely seated on base. I unplugged the unit, unscrewed the plug on the tank and screwed it back on and then made sure the tank was securely seated on the base, plugged it in and it started working. If the tank is full you may just have to make sure the tank is fitting properly in the base.
Feb 05, 2014 | Homedics Uhe-oc1 Cool Mist Ultrasonic...
Fan and tank lights won't run
I would look at the floating switch actuator. It's common for the float to bind up in the holder which keeps it in place. If the actuator is floating free, then look at the switch itself. Could be corroded or otherwise malfunctioning.
Nov 26, 2013 | Bemis 447 301 Humidifier
Won't blow mist out
I have a similar problem. I found a crack in the tank. I am trying to find out if it is cheaper to replace the tank, or just buy another one. I have tried other types and like this one the best.
Dec 22, 2012 | Walgreens Cool Mist Humidifier, 1 ea
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried...
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Post comments  for more help or information .........
Good Luck!!
Thanks
Dec 22, 2009 | Holmes Products Cool Mist HM3500...
I was up all night with this since I just purchased it yesterday and I wanted to be certain that there wasn't some simple alternative to returning the humidifier since the reset light keeps going on immediately after I turn the unit on AND I've already followed all the directions to the T. Believe me - I was ready to return it cause ain't no 38.99 worth me doing all this tinkering and trying to figure out why they couldn't make the unit correctly cause apparently A-LOT of people have this problem. If it wasn't for my three children being so ill including myself getting sicker going out to purchase the humidifier and I was trying to avoid going back out to further compound my illness----I WOULD have just returned it. MAYBE I still will return it. ANYWAY, here's the deal: the water in the tank SHOULD flow into the boiling chamber where of course steam rises from there; however, the WATER VALVE in the CAP to the water tank does not allow any water to flow into the boiling chamber because it is so tight. The reset light goes on as if there was no water in the tank because of course, the heater is on, but no water is getting boiled because the water can't get in. There are a few things you can do. First: the water valve is a little stick and a spring within a piece of rubber that can be slipped out of the cap (this is what I chose to do). Now the water flows easily and even with the unit set to high, there is no problem. It just works. Second: You could remove ONLY the stick and spring from the water valve's rubber piece. This would work if the hole in the rubber piece happens to allow steady water flow (mine wouldn't). Third: you could probably do some cutting til you were satisfied with the results.
Feb 06, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Sunbeam Humidifier. 0.65-Gallon Warm Mist Humidifier SWM2412-UM Logo
87 people viewed this question
Top Sunbeam Humidifiers Experts
Oloyede Monsuru
mike
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
