Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
Knocking crunching noise that gets worse the further you go
Sounds like a bearing breaking up
  • Pride Mobili... Master
  • 1,263 Answers
Hi ,Philip, Sound like the gearbox leads some lube if it's not too late, could be the diff crunching broken bits of gears, Sadly I strongly advise you not to use it ...Are you in the UK ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Feb 19, 2014
Washer making noise in the spin cycle sounds like a roller or a baring
if its it sounds like a plane engine starting up its the bearings in the rear tub its quite a large job to do, if its a horrible crunching/banging noise one or more of the spider arms has broken on the rear of the drum which is much worse than bearings as it often causes damage to other things
Jan 30, 2017 | Washing Machines
L200 series read knocking noise
Sounds like a loose or broken brake shoe or brake drum. As the car is slowly moving, pull up on the emergency brake. Does the noise get worse? Better? Can you feel the clunk in the handle of the E brake? This is what it sounds like, but my second choice would be the wheel bearing getting bad. These cars are known for this. If you jacked the car up a bit and wiggled , tugged , and pulled on the wheel, you may find movement there. If so, it is the bearing. . I changed my bearing 3 weeks ago. l series, $51 for the bearing, and $40 to press it in. I took it off the car myself. Very easy to do. If you decide to go that route, I can walk you through it. Hope this is helpful, cheers from Nova Scotia!!
Jan 17, 2013 | Saturn L-Series Cars & Trucks
My son has a 99 Pontiac Grand Prix, when he's driving it, it's making a knocking noise on the passenger side by the tire. Could it be a suspension or bearing issue?
Try turning the wheel and seeing if the knocking noise gets worse or better.Usually when you get a knocking like that or a clicking when your turning,you need to replace the CV shaft on that side.Sometimes a wheel bearing will make a click but if you jack up the car and can hold the wheel from top to bottom and can wiggle it and feel alot of movement that is the wheel bearing but it is probably the CV shaft making that knocking noise.Good luck
Aug 23, 2011 | Pontiac Grand Prix Cars & Trucks
Honda Integra DC2 knocking noise
Sounds like your describing a bad wheel bearing.
Sep 27, 2009 | 1996 Honda Accord
Strange noises
shoks may be good but your springs may be faded, as for the birdies cherping you may have a worn tensioner bearing for one these, a/c belt, alternator, water pump bearing, check spark plugs & wires conditions for knocking
also check for loose or failed engine mounts
Jul 21, 2009 | 2003 Nissan Maxima
Breaking at slow speed there is a bad bearing o scrunching noise.
This is a hub issues. the bearings are dry and i would get this looked at before they get to dry. i would also check the entire axle assembly as well. just too be safe. i suspect the bearings will need to be replaced. (repacked)
Mar 15, 2009 | 1999 Chevrolet Malibu
Noise when driving
it sounds like a bad main and thrust bearing
Feb 28, 2009 | 2008 Nissan Rogue
Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
65 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
