Question about Numark C2num Five-channel Rack Dj Mixer
How to connect every thing correctly - Numark C2num Five-channel Rack Dj Mixer
Engine wont start
there are so many things that you may not have done that is the problem
are all the harness connections clean and tight and correct?
is the cam and crank sensors connected ?
is the immobilizer connected ?
is the ignition control module harness connected ?
are the coil wires connected correctly?
do you have fuel pressure in the fuel manifold?
are the injector harnesses connected ?
have you used a scan tool to reset the ECM?
Feb 15, 2016 | 2002 Dodge Ram Pickup 1500
No sound coming frow soundbar
Been there, done that. Check to ensure input is on the correct channel. I spent weeks trying to resolve the same issue and found that the connections that were "as they should be" were not correct, so double check connections as well. If all else fails, contact manufacturer for assistance. (I know that is a hard thing for a guy to do)
Dec 31, 2014 | Audio Players & Recorders
How to add Freon to 2005 dodge Durango 5.7L HEMI V-8
This is one thing I insist people have a technician do. If you do not do it correctly two things will happen -- damage to the compressor and damage to the environment. First you need to have the CORRECT grade of Freon, and you need the access tool kit to make the connections and you have to have the correct volume of Freon.
Oct 08, 2014 | 2005 Dodge Durango
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
My internet is not yet connected
For you to connect to internet your laptop must a wired network card or a wireless card.You can still connect using a modem connected to your PC.MAke sure you have the correct IP address,subnetmask,gateway address and DNS configured correctly.But if you are using a DHCP server, all this setting will be automatically configured for you.
Note the first thing you have to be sure of is that there is internet access and that your laptop is free from infections.
Regards.
Dec 09, 2010 | Computers & Internet
My mobile is not connecting from pc because I have not correct software pls reply correct soulution.
the best thing you can do is go to the website of your mobile phone, there you can download the software to connect the phone with the computer.
hope this helps ya.
grtz
Aug 23, 2010 | Computers & Internet
I'm doing my first system build. I have everything connected but it will not boot, fear I might not have MOBO wired correctly it is an Abit AN52. Any help would be great.
First off disconnect any devices connected to the board, hard drives, dvd-roms, leave the the memory, processor and power lead connected to the board, try to boot it up.
If the fans run then the power switch is wired up properly, next check the graphics, ensure it is in the socket properly and all power connections are connected up.
If it still dosent boot and you have the manual for the motherboard look for the bios jumber, there are 2 settings normal mode which lets the computer boot, and the other that dosent allow boot, this jumper is normally J12, but have a look in the manual for the motherboard to make sure, if you try all of this and the system still will not boot please post back
Feb 03, 2010 | Abit AN52 Motherboard
Cannot open internet when trying to get wifi
Ok - few things to clarify first:
When you say "it connects" what do you mean? Do you open internet explorer and can browse the net without problem?
You Pick up Wifi connections - make sure you pick the correct one to connect to and ensure that you use the correct Password.
If all the above are working then make sure the Laptop is rebooted when you attempt to connect to wifi. Msn has problems when it can not resolve correct IP address - rebooting the machine should fix that.
Or the connection speed is too slow - which these days can still happen.
Finally, Get the full error message from msn and type it into google. Guide yourself to the Microsoft pages with the correct solution.
So few things to clarify and few things to test out.
I hope this helps, don't forget to rate my solution.
Thanks.
Apr 13, 2009 | Toshiba Satellite A105 Notebook
My motherboard isnt turning on
my motherboard is connected correctly but when i turn it on, the screen remains off and i put the bios_wp thing on the motherboard correctly but it still wont turn on and the processor fan turns on but nothing appears on the screen and the screen works well....same as my problem did you get then solution
Apr 04, 2009 | EliteGroup P4M800PRO-M478 Motherboard
Can't connect to router
do one thing re-configure it your router and correctly information then check your isp side your dns and ipaddress every thing which isp people give to you.
Jul 05, 2008 | ASUS Computers & Internet
Numark C2num Five-channel Rack Dj Mixer Logo
26 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
