Question about Creda Kitchen Ranges
Creda C366E when main fan oven is swithed on after about 2 Mins it trips main fuse box.
5 Suggested Answers
  • 209 Answers
SOURCE: smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Posted on Sep 09, 2007
SOURCE: fan oven not working
Hi, did you ever get this sorted, as i think the same thing has happened to my oven.
Posted on Oct 31, 2007
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
dmftrucker
  • 1922 Answers
SOURCE: Hygena oven trips main fuse box when switched on
sounds like that element is getting a "hot spot",high resistance area, will oven operate w/o that element in place?you also could have a bare wire touching the oven case somewhere, if it trips w/o having anything turned on remove back cover and examine all wires and connections
Posted on Aug 23, 2009
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
My creda cooker lost power when I turned on the grill but did not trip the main fuse and there is still power at the main swtch
Is it a built-in model? If it is then there is sometimes a wall plug in a cupboard that may have a fuse in it.
Feb 01, 2016 | Creda Ovens
WHATS WRONG
When cleaning, did you get anything wet?
Jan 20, 2012 | Cars & Trucks
Switched bottom oven on, then noticed it had tripped fuse for cooker in main fuse box. Swithed it back on and it wouldn't heat up. The fan and light were ok! Top ove? grill works ok still.
sounds like you have a heating element burned out. Look real close at the heating elements and you may see a hole burned in the metal tube. This is a sure sign of a bad element. Some elements are easy to unplug. Others a real pain. Always unplug and or turnoff breaker prior to unscrewing anything. If you fine the bad element just unplug and other element may work OK. Best to get your model number and search net for new element.
May 30, 2011 | Ovens
Hi. I have a hotpoint ud47i fan assisted oven which keeps tripping the oven related fuse box. Can't find any obvious faults. Strange thing is that once I reset the fuse box, the oven works again for 5-10...
The oven is tripping the circuit because it is pulling to many amps.
Best thing to do is get an electrician to install a larger amp circuit for you. This will fix the problem and should be cheaper than another stove.
Mar 27, 2011 | Hotpoint Microwave Ovens
Oven fan wont work
You need to determine if you are getting a mains feed to the fan motor, if not, then you need to trace the wires bcck to source and work from there,
If you are getting a 240 volt supply, then the new fan is faulty.
Hope this helps you.
Dec 15, 2009 | Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Fan oven not working
Sep 03, 2007 | Stoves Newhome ECH600MXa Electric Kitchen...
Kitchen Ranges Logo
Top Creda Kitchen Ranges Experts
richie46
ray gallant
Gerard Curran
Are you a Creda Kitchen Range Expert? Answer questions, earn points and help others
