Question about Dishwashers
Zanussi model 50400114 - Dishwashers
I cant get child lock off zanussi 6kg 1200 and cant find the manual please help
Zanussi has several washer models with 6 KG capacity 1200 RPM spin speed specifications. You need the model number to find the manual here: http://www.zanussi.co.uk/support/manuals/ . The model number for a front load washer is inside the door on the lower right of the opening.
For the ZWG7120P, you need to press and hold both the Temperature and the Spin buttons for 6 seconds to toggle the lock on or off. (This time is approximate.) These are the two buttons closest to the program selector dial. There is a small padlock icon in a curved line below and between the buttons. The direct link to the manual for this model in English is http://www.electrolux-ui.com//DocumentDownLoad.aspx?DocURL=2010\132\948930EN.pdf .
I hope this helps. Please add a comment with your washer model if the above child lock directions do not work on your machine.
Oct 06, 2016 | Zanussi Washing Machines
Can you send me a repair manual and wiring diagram of ZANUSSI Model:FCS101E4, PNC 9PDD24031404, Made in EU
Sorry we do not have this material, it is proprietary and you need to obtain it from the manufacturer.
Sep 05, 2016 | Zanussi Ovens
Can the Zanussi oven, set for LPG, model ZCG660GXC be converted to be used with natural gas?
Zanussi ZCG660 Manuals
EW 1200 i on manualslib.com
Dont know if you have a manual. On page 21 it says:
Gas Category 13+
Gas Supply G30/31 (3+) -
28-30/37mbar
page 22 shows more settings 20mbr for natural gas
however instructions are not valid in all countries.
I went to www.zanussi.com it asked pick country and Egypt I picked. There is a support tab see if that gets you closer than Italy or Switzerland.
Good Luck looks like a great oven.
Zanussi Start
Mar 31, 2015 | Zanussi Kitchen Ranges
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Ai need a new motor for zanussi dryer model no td
You'll need to contact Zanussi Service center in case you want to buy new motor, Visit this Link and put your postcode to locate nearby service center.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Zanussi TC7114W Electric Dryer
Where can I get a manual for my zanussi aquasave dw24
Your model did not appear on my search. Here's a link to Zanussi DWs, check your model number again and check here:
http://www.fixya.com/support/zanussi/dishwashers
Best regards, --W/D--
Aug 18, 2009 | Dishwashers
I need to know what the model no is for a zanussi aquacycle 1100 xc washing machine as I have a problem with the drain um and would like to urchase a new one but do not know the model no of the machine
if you look on the back of the machine there should be a label there with the model number. (Or inside the users manual)
http://www.zanussi.co.uk/ or go here and click on 'Contact Us' to find out directly fron Zanussi.
Nov 08, 2008 | Washing Machines
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Dishwashers Logo
14 people viewed this question
Top Dishwashers Experts
Owen Barnes
