Question about Iview 754TPC with WiFI 7" Dual Camera, Touchscreen Tablet PC
Wifi turned off and locked out - Iview 754TPC with WiFI 7" Dual Camera, Touchscreen Tablet PC
Cannot unlock WiFi, there is not a command or switch to remove lock out symbol
Try clicking on the "X" in the top right corner. Sometimes that will allow you to do it or it turns the switch off. Good Luck.
Dec 26, 2015 | Tablets & eReaders
I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ‎23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ... Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
Dec 15, 2015 | Tablets & eReaders
Certain apps that need wifi don't work even though I have perfect wifi signal. I've already restarted my iPad mini, charged it, and turned on and of the wifi a few times, but that didn't help
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
Dec 30, 2014 | Apple iPad mini 7.9" 16 GB Wi-Fi 4G White...
My Wi-Fi is in the locked mode. How do I unlock it?
If I were to guess what you are trying to say is that when you go to the wifi in you system setting, you see a lock next to the wifi network name ?(SSID) The lock indicate that the wifi network you are tring to join has a password that need to be entered to access the network. Ask the person that did the setup on die wifi router for the password.
Dec 27, 2014 | Apple iPad Air 9.7" 16 GB Wi-Fi Silver...
How can I unlock device with the Wifi off?
The default passcode (WEP etc...) is usually on the router. Hopefully he didn't change it.
Sep 26, 2014 | Craig 7 Inch Capacitive Multi-Touch...
How do i unlock wifi when it is showing locked
If I understand your question correctly, if a wifi signal is shown as locked then you need to put in the wifi password to unlock it for your device.
Hope that points you in the right direction
Have a Magical Day!
K
Jul 26, 2014 | Apple iPad Tablets & eReaders
Why is the WiFi in my rca tablet killing my battery to fast
Wifi always drains battery life to some extent or another.. Best solution is to turn off wifi when not in use or needed, and or keep your device plugged in during extensive use.. try to figure out your battery life while using wifi, and also kill/turn off any unnecessary background apps like gps, etc.. you can also extend your battery life by keeping your back light and lock screens to turn down and set to automatically turn off after a min or so of non use.. hope this helps..
May 04, 2014 | Tablets & eReaders
To many pattern attempt
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Apr 15, 2014 | Samsung Galaxy Tab Tablet PC
To many patten attempts
Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
Iview 754TPC with WiFI 7" Dual Camera, Touchscreen Tablet PC Logo
13 people viewed this question
Top Iview Tablets & eReaders Experts
Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
