Question about Whirlpool Washing Machines
Clean filter whirlpool duet resource saver - Whirlpool Washing Machines
Jahn27
  • 1554 Answers
SOURCE: How do you clean out the filter on a whirlpool
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Posted on Feb 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: take off whirlpool duet front panel for filter
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: hello my stupid whirlpool duet sport washer keeps
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
  • 6277 Answers
SOURCE: How do I clean the
Hi Natasha from retired Englishman in SW France,
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 07, 2011
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not spin all water out of a blanket
The number one cause of all spinning/draining problems with the Duet washer is a clogged filter screen on the drain pump, I have written this tip that shows how to check/clean that filter.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i clean the pump filter on a duet washer
take the kick panel off. dead center you will see it
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where is the filter located that is suppossed to be cleaned
If this is a Whirlpool Duet or Kenmore Elite front loader, the filter is the drain pump reservoir. The following link explains how to access and clean:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you run into any difficulties, or have additional questions, please let me know. I hope this helps you.
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
