Question about Kenmore Refrigerators
Power issue kenmore 795.77302600 all power off, no lights. not on, power source is active,
I have a Kenmore 106.56163500 that the ice dispenser is not working. I have replaced the ice auger motor. When you depress the ice door lever nothing happens. What next?
The new augur motor is not being energized. Check the circuitry that feeds it power and you will find the source of the issue.
Mar 16, 2017 | Kenmore Refrigerators
Amp wont play
Quick test...with your Lanzar volume all the way down, connect MP3 player or other type audio source directly to the subwoofer input connection. Play audio and slowly increase volume control. If subwoofer is working using this method, reconnect and check for audio output to Lanzer connection problem, or subwoofer "settings" issues with the receiver.
Nov 11, 2013 | Lanzar VCTBS8 Vector 8-Inch Super-Slim...
Television won't turn on, either by remote or pushing button on t.v. itself. light just flashes. worked fine last night
The status light flashes to signal that the power source is in protected mode. This mode has been activated by the protection system of the power source this morning, when you tried for the first time to start it. It has been activated because during the night a part inside the tv has failed and has started to act as a short.
The only way to fix that is to open the tv, test the power source, identify the power rail that is down and has triggered the protection system, follow the rail and test all components that are powered by it till you find the failed one then replace it or the whole board on which is situated.
To do this requires electronics experience, if you don't have it then call someone who has it. Or take the tv to a repair shop.
Dec 29, 2010 | Proscan 32LA25Q 32 in. LCD TV
We try to terun on the TV, the blue light is on and the TV do not work
If only the blue line is on - nothing else - that means that the power source has been shut down. How this happened: in your tv there is a faulty board - on your model it's usually the inverter board, the board that powers the CCFL tubes that provide the back lighting; when you try to start the tv the power source of the tv gets activated and it starts to deliver the current to all the other boards of the tv; the faulty board absorbs way more current that it should - this is detected by the power source who goes full power to compensate; but this isn't enough and the voltage drops - this triggers the protection system of the power source who shuts it down by force. When the protection system is activated you just can't do anything else but to unplug the tv from the mains.
The only way to fix that is to repair or replace the faulty board and this is a job for some one with electronics experience - time to call one.
Nov 06, 2010 | LG 42LC2D 42 in. LCD HDTV
My lights are flashing on my Kenmore Washer machine HE3 110 Series. How do i reset it?
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 20, 2009 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore 110.24962300 washer and a 110.75962300 dryer that wont turn on anymore. No power light on I had them stored in a garage for a few months and now neither of them will power...
If it is both units, it may be the power source. Were they on the same circuit? If so check to see if the power is clean (120v, at 60Hz and a good breaker). It sound like you have tried different receptacles but were they on different circuits? Also the electronics may have been fried from a surge or in storage pest or something else may have gotten to the wires.
Jul 18, 2009 | Kenmore Washing Machines
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Question on BB2125 2 Channel Amp
Hi jgoudie
It is a signal sensing turn on unit, so will not turn on until you have supplied signal to it. Plug it into a signal source and see what it does. But unfortunately, in my experience the protection light coming on means there is a fault in the amp.
You can download the user manual for the amp from here. Click downloads in the middle of the page:)
regards
robotek
Aug 17, 2008 | SpeakerCraft BB2125 2-Channel Amplifier
Agitator
try putting a new coupler in it
Mar 19, 2008 | Kenmore 20722
Kenmore Elite Oasis Electric Dryer
i have the same problem only the drum light will come on i opened up the top console and found the tech sheet and after going thru the tech sheet with a multi-meter according to the results i will need to replace the user interface assembly, p/n 3407184. you too may have the same problem.
Jan 07, 2008 | Kenmore 67082 Electric Dryer
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
