Question about KitchenAid KIRD861HSS Kitchen Hood
Kird861VSS This is a retractable downdraft vent system. the top of the unit is a stainless steel assembly with a button in it and three "posts" that are designed to snap into the main unit. for some reason, the posts seem to short and do not attach to the spring clips below, so the top bar never attaches. have others seen this? what is the right solution?
3 Suggested Answers
SOURCE: Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Posted on Feb 03, 2010
SOURCE: Downdraft vent won't stay down. Push the button
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Posted on Mar 20, 2010
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
How do I fix KitchenAid Retractable Downdraft Vent System?
No model number but they are pretty much all the same you have a failed micro switch behind each filter screen is one rarely see them go bad but filters have to be in place for unit to work, depending on model there are either two or three switches around the motor they are pretty aggravating to get to they are located in the panel below the cook top some models require the removal of the blower motor and housing and depending on the install still my not be able to remove the main panel if you can get past all of this to the switches don't waste time testing them just change all of them they get grease in them which won't allow the contacts to mate
Jan 23, 2015 | KitchenAid Dryers
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
Which is the best pop up down draft vent system? Do you have any reviews?
I wish I could offer some help but I am trying to solve the same question. There are almost NO reviews out there on the internet for any downdraft vents. There are also NO noise ratings on the fans (though ceiling fans all have ratings). It would seem that the taller the vent, the better positioned it is to draw off cooking fumes but other than that and the power of the motor (and perhaps ease of cleaning), I've no idea how to select a unit. HELP!
Aug 28, 2010 | KitchenAid KHTU165RSS Stainless Steel...
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
30 INCH TELESCOPING DOWNDRAFT VENTILATION UNIT
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Sep 04, 2008 | GE Profile JVB67HWW 36" Telescopic...
Dacor downdraft vent
YOU WILL NEED TO CONTACT A AUTHORIZED DACOR DEALER OR PARTS DISTRIBUTOR I SUGGEST CALLING FOX APPLIANCE IN ATLANTA GA OR THE MFG IN BERKLEY ,CA
May 26, 2008 | Kitchen Ranges
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Call Dacor at 800 793 0093. They'll tell you who has the part.
Dec 03, 2007 | Dacor RV36SS Kitchen Hood
KitchenAid KIRD861HSS Kitchen Hood Logo
101 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
