Question about Philips PET710 Portable DVD Player
Smashed screen My daughter closed the lid of the dvd player with her ear phones inside and they smashed the screen.
  • Mathew Hewlett
    Mathew Hewlett Feb 10, 2014
    I just want to know the best place to get a replacement screen.
When I open the dvd lid, and I put the dvd in and close it, the screen still says its open and it wont do anything until the dvd lid is closed. Even though I close it, the player still thinks its open.
There is a mechanical switch that is operated by the lid as it's closed. Sometimes, a DVD player such as yours can be made to work by pressing down on the lid but this is a sure indication that something is wrong with the switch. It isn't practical to hold the lid down for the entire time you're viewing a movie so repair or replacement is the only solution
Nov 17, 2012 | Mintek MDP-1815 Portable DVD Player
No disc is showing on screen when a movie dvd is inserted. There is no spinning.
If there's no spinning noise check that it is closing completely (lid usually makes contact with something inside to initiate loading).
Alternate possibilities - check battery may not be holding a charge, charger may be bad - also if player has a lot of miles on it the motor may have burned out
Jun 18, 2010 | Philips Magnavox MPD845
Inside screen cracked??
Hello. Take the phone into the phone store and they will repair it for you. Joe
Mar 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Says open on screen but door is closed and movie wont play
The switch that detects whether the door is open or not could be defective. You can locate the switch by the notch on the disk lid and where it inserts into the base. Try triggering the switch by pocking it with a paper clip while the lid is open. If it says that it is closed and the disc plays then the lid isn't closing securely. If it still says the lid is open after you can hear or feel the switch click then it may need to be replaced.
Jan 07, 2010 | Coby TFDVD1020 Portable DVD Player
I put a dvd in my portable dvd player and close the lid on the dvd player but it keeps sayin its open when its shut!! therefor it wont play any dvds!
LID SWITCH IS BROKEN, CHANGE IT OR THE COVERLID WHICH HAS A SMALL 3MM SIZE OF PLASTIC MATERIAL WHICH PRESS THE SWITCH WHILE CLOSING IS BROKEN TRY TO MODIFY IT...
Oct 13, 2009 | Goodmans GCE5000 Portable DVD Player with...
I have a Tru tech portable dvd player model no. 12701C, and i cant get the lid to close or the dvd player to read the disk i believe because it turns on and just says "Open" on the screen...the dvd inside...
Unfortunately, if the lid will not close properly, there is nothing you can do to fix that. Furthermore, if while holding the lid down the unit still shows "open" on the screen, the unit definitely needs to be repaired or exchanged. If you're in warranty, contact the manufacturer or the extended warranty company for the procedure you'll need to follow.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 07, 2009 | TruTech PVS12701 Portable DVD Player
Dvd region code
switch on.
open lid.
press STOP on remote.
enter code 2379 on remote.
region code list will appear on screen, using the UP/DOWN buttons on remote select required region (9 is multi-region).
press OK on remote.
close lid.
press STANDBY on player
OR
1. Power ON
2. Open Tray
3. on the remote use the code.
359735
4.Use region 0 to make player region FREE.
May 20, 2008 | Durabrand DVD-1002 DVD Player
Portable dvd player Film's stop and go back to loading screen
Not sure it's a solution, per se, but I discovered that my Matsui was acting as if I was opening and closing it, so I guessed that it was the lid. Once I put a paperweight on the "Press to Open" part of the lid, the DVD played through. I'm looking how to fix the lid but that's a workaround for now. Best of Luck - M
Jan 26, 2008 | Televison & Video
Mintek DVD Player
Should be 2 prongs....accordianman
Nov 16, 2007 | Mintek MDP-1815 Portable DVD Player
Philips PET710 Portable DVD Player Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
