Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Mi copiadora xerox xd100 marca error j2 que es
4 Suggested Answers
  • 239 Answers
SOURCE: Xerox XD100 that is showing a code J2
If this code just came on, you have about 2,000 copies to run before the machine completly will not run.
This machine will run so many copies before it end of lifes the drum unit.
In the old days, these drum units were serviced by the service representative.
Nowdays, the cartridge just runs to the end of life on the cartridge. Most cartridges will run for about 15k with 2k to use to allow the user to order a cartridge.
Even if the cartridge is still good, the cartridge is end of life at the maximum allowed copies on the crum.
If the problem still exists with a new cartridge, the service repair for this is more involved and needs a service manual and someone who knows what they are doing to do the service in diagnostics mode.
I have preformed this many times before.
The NVM settings need to be rechecked and the main board may need to be reset.
Very involved.
Place a Xerox service call to have this repaired.
Posted on Oct 23, 2009
techman007
  • 1112 Answers
SOURCE: J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Posted on Dec 15, 2009
  • 42 Answers
SOURCE: la impresora phaser xerox
Vuelva a colocar el cintur?n de la unidad de transferencia
Posted on Jan 17, 2011
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Aug 22, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Hola mi copiadora es canon image runner 400s y me da un error de una llave con un codigo E051 PORFAVOR AYUDARME GRACIAS
En los equipos de fotocopiado o copiadoras es difícil que aunque yo te diga, a que se debe la falla tu la arregles, nos a pasado que los clientes meten mano a los equipos y los descomponen mas,te aseguro, que esto no es por molestarte, te aconsejo que llames a un técnico, especializado, siempre que tengas problemas importantes. http://www.copiadorasfandis.com
Mar 09, 2011 | Canon imageRUNNER 400S Copier
Mi copiadora IR 5020 se para y arroja cod E 0000020 y manda a apagar y encender el equipo que es este error
check the toner hopper maybe the toner is empty or the hopper motor is failed to fuction
Dec 03, 2010 | Canon imageRUNNER 5020 Copier
Impressora xerox 3300mfp aparece o seguinte erro: BB-data mgr.c 487 internal error wer: off/on
Ese error lo manda porque ya la bateria de respaldo que lleva en el tablero(generalmente de 3.6 volts) ya lleg? al fin de su vida y hay que remplazarla, en mi caso me lo hizo en una Dell 1815, pero la marca fabricante es Samsung, abarca Dell, Samsung y Xerox, esas bater?as eran tres marca Varta tipo bot?n grandes en serie de 1.2 volts que sumaban los 3.6 volts,como son muy dif?cil y caro el conseguirlas lo que hice fue soldar los terminales de los cables positivo y negativo a una bater?a de celular recargable que ten?a el mismo voltaje y se lo pegu? con silic?n a un espacio en el tablero y ya funcion? bien.Ojal? y este tip les sirva.Les mando un saludo amigos.
Dec 01, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Me marca el problema u14
La botella de desperdicio de toner esta llena, hay que vaciarla y limpiar bien.
Sep 27, 2009 | Panasonic Workio DP-1820P Laser Printer
Se reinicia a cada rato
tengo un problema con el ADF de una Xerox Pro 215 cuando quiero copiar algo se van las hojas en fila no juantas sin separarlas una por una que podria ser el prolema alguien podria alludarme
Dec 03, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
