Question about Sewing Machines
Bernette 46 Motor
I'm a beginner with machines and just recently got a Bernette 46. It is beautiful, but has a very strong motor, which makes sewing even a straight line a challenge. I have used other peoples' machines (different models) and when I press lightly on their presser feet, I can stitch slowly. When I press lightly on mine, it goes about 80 mph and makes it hard to stitch. I've asked around and I'm told the motor can't be adjusted since the machine isn't computerized. Is there any solution for this?
    Champion:
  • 276 Answers
Sounds more like a foot pedal fault rather than the motor, try another foot pedal. It sounds as if yours is faulty
Posted on Feb 19, 2014
3 Suggested Answers
  • 1788 Answers
SOURCE: I have a singer simple
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
Posted on Dec 27, 2010
  • 517 Answers
SOURCE: I live in Ecuador. I
Good day!!!
If your screen stated"main motor blocked" then I suggest you remove the thread,both the top and the bottom.Please change the needle too.but If the problem is unsolved,kindly loosen or unscrew the casing which is in the front of the bobbin, then look/find anything that might be obstructing the bobbin. check again the thread, bobbin and needle.Also for the last thing put an oil to the parts which you think it needs it like the moving parts re-start or reboot it then leave for a whole night.
Thank you and good luck...
Posted on Jul 22, 2011
My bernette 46 will not wind a bobbin. It runs about one rotation and then stops
For ~$30 you can pick up a stand-alone bobbin winder (Sidewinder) at JoAnn's or Amazon. It's a handy little accessory as multiple bobbins can be wound without unthreading the sewing machine, plus it saves wear n tear on the machine.
Jan 15, 2018 | Sewing Machines
I have a Bernette 335 serger. The power comes on,light works but will not sew when I push on peddle. I purchased a new wire harness, but still will not sew.
Does your machine require regular and frequent oiling? Sounds like it may have seized due to old, dry oil. If this is the case, refrain from forcing the motor to run when the machine is locked. It could damage the motor,
Aug 04, 2017 | Sewing Machines
Where can I buy an online manual for Bernina Bernette 46
Hi Shiela,
You may want to check this manual I found. Hope it helps.
Bernina Bernette 46 Manuals
Apr 25, 2014 | Bernina Sewing Machines
Where can I find an online user manual for Bernina Bernette 46
Hi Sheila,
I have this manual for you that might help your question. Hope it helps.
Bernette Deco 600 is there anything that can be done, short of taking it to be repaired, for a locked motor?
To be honest, probably not. I'm assuming that the motor simply wont turn at all, even when released from the main drive. This could be a number of things ranging from the brushes worn through so that a contact spring has bound-up on the rotor contacts (I'm not sure that the brushes can be renewed on this motor anyway) to a complete seize of the rotor due to overheating - if the latter, then the motor is a write-off anyway. Get it checked-out professionally.
Nov 19, 2011 | Bernina Bernette Deco 600
I have a Bernina 707 and it needs a new motor, are these still available.please
They do not make them anymore. Your only solution would be to a used one from a working machine with the same model number.
Mar 06, 2011 | Bernina Bernette 75
Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Sep 16, 2008 | Bernina Bernette 75
Bernina bernette 65 tension
my bernette do not teke tha low strak
Jul 13, 2008 | Sewing Machines
Motor for my Bernette 335 overlocker
Yes, motors for sewing machines are very easy to replace with suitable replacements. They are quite common in other industries and the specs are pretty much identical. Happily a sewing machine motor is rather easy to replace compared to most other assemblies on it. I will always urge you to take it to your locally certified Bernina dealer or contact one online, make sure to confirm your model and serial number and a replacement can be sent out to you. Sergers are a bit tricky in taking the covers off and ensuring minimal damage to the plastic so I would recommend you take it to a service tech first before trying yourself.
Mar 11, 2008 | Bernina Bernette 75
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
