Question about Kenmore HE5 Electric Dryer
Where do I get a repair manual for my He5?
I need wiring diagram. I did an annual clean and crossed the wires on the thermo fuse and blew the contacts clean off. I need to find the correct wire connections
  • Anthony Moore
    Anthony Moore Feb 10, 2014
    i already checked in the dryer and and around the control board and console. I did not see any packets with schematics.!
    Scholar:
  • 163 Answers
Http://www.searspartsdirect.com/partsdirect/user-manuals?sidPSx20071217x00001a&ibp-adgroupsearch_brand_manuals&ibp-keyword%2Bkenmore%20%2Bmanual&ibp-matchtypeb&gclid=CJrxyOv3wrwCFaxxOgodF24A2Q
Posted on Feb 11, 2014
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
SOURCE: kenmore dryer wiring diagram
Can I get a diagram to fix the heating problem for a Kenmore dryer?
Posted on Jan 16, 2009
buffalonyman
  • 1865 Answers
SOURCE: Gas Dryer Blows Cold Air Only
Its more likely the ignitor went bad, and you can order the part from sears online. The ignitor is listed at $29.59
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11070902990&productCategoryId=0151200&brandId=0582&modelName=GAS-DRYER&diagramPageId=00001&componentDescription=3402851%20BURNER%20ASSEMBLY&documentId=10052249&backToLink=Return%20to%20Sub%20Components%20list
Posted on May 06, 2009
  • 142 Answers
SOURCE: Kenmore dryer model 110.62066102 electrical wiring diagram
contact manufacture.
Posted on Sep 14, 2009
I changed the element and cleaned the connections on thermal fuse and thermostats. Will there be issues if something got crossed?
The element gets 240 volts I doubt you could cross a wire and not trip a breaker. The element is in series with the fuse and thermostat
May 23, 2015 | Whirlpool Dryers
Need the wiring diagram for main fuse 2010 toyota sienna
oh darn... someone in your area has Mitchel on Demand or Shop Key... Offer them a 12pk of their favorite adult beverage to print you out your needed info or check with your local library
Dec 28, 2013 | 2010 Toyota Sienna LE
2006 Suzuki GSX-R 600 wiring diagram
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Suzuki GSX 600 wiring diagram Google Search
Suzuki Motorcycle Wiring Diagrams
Suzuki GSX R600 Manual
OEM parts for Suzuki
Suzuki GSX R600 2003 Owner Manual
Sep 22, 2017 | 2006 Suzuki GSX-R 600
Fuse keep blowing after crossing speaker wires.
Fuses blow when there is an overload. In your case when you crossed the speaker wires you shorted the main amp. This now has a part that is acting just like a strand of wire.
Trace back the channel you crossed the wires and find the main output device(s). Then replace them. They will be located on a heat sink if that helps.
Jul 03, 2017 | Sony MHC-MG510AV Shelf System
When i turn on my directional signal, the headlights blew out, than i turned on my high beams and my high beams blew out instantly. what is going on and why does this happen and how can i fix this problem?...
No it wouldnt be acceptable as the vehicle wouldnt be original fittings for the annual test ,you need a new stalk switch thats all the wires have shorted out inside the switch unit and i doubt if its repairable
Feb 15, 2011 | 2000 Hyundai Sonata
06 mazda 6 battery was crossed polarized, however the TCM fuse blew and we were able to start the car. Now the car shifts hard and will not shift out of third it seems. Any suggestions,? is the TCM fried?
Sounds like you may have fried the tcm I would go to car-parts.com and get a good used one. You could check and see if there is any fuses that you blew out that control the tcm if you have a manual for the car you can look at a wiring diagram and find out what fuses are associated with the tcm if not check them all.
Nov 30, 2010 | 2006 Mazda 3
RTH221 honeywell thermostat install, hooked up blue wire from old thermo that hooked to C to o/b connection on new thermostat no work did I screw something up as old thermo will not work as well now. was...
maybe a blown fuse if it has one... if not then you blew the transformer...
Check on the circuit board in the furnace or air handler for a fuse...
if there isn't one... then you will need to replace the 24v transformer... they blow very easily...
heatman101
Aug 05, 2010 | Honeywell Heating & Cooling
When i start the car a fuse will pop and then the car stop running
I've had a similar problem in my 95 dodge neon recently. What I did was I accidentally wired something completely wrong. I wired my rear driving lights to a constant 12V source wire, thinking it was a ground wire. Blew 6 fuses before I realized what I did. Anyways, try to get a hold of an electrical diagram, and make sure there are no shorts or crosses between anything. Odds are your wiring is off a bit.
Oct 06, 2009 | Dodge Neon Cars & Trucks
Fuse diagram issue acura integra
it should be printed on the inside lid of the two fuse boxes...also it's printed in the owners manual.
Jun 17, 2009 | 1997 Acura Integra Type R
Kenmore HE5 Electric Dryer Logo
140 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
