Question about Dell OPTIPLEX 745 PC Desktop
I tried to hook up my Dell Optiplex 745 and I herd a split second pop.
I moved to Europe and I brought my computer with me. I hooked everythink up the right way and for got to flip the switch on the back of the computer to the right power and I plugged the computer to the nearest wall outlet and for a split second a pop sound happened. Now the computer does not turn on! What happened, how can I fix it and what? If it has fuses, where are they? I was in a rash to get everything packed and ready for shipping, so I did not even think about the switch on the back. Please help me and tell me what to do!
  • 3 Answers
It is likely your power supply was fried, but this does not mean you are out a computer. Bring it to a local repair shop and they can swap your power supply that can adequately charge your components.
Posted on Feb 10, 2014
  • 3940 Answers
SOURCE: An old Dell Optiplex gx260 just won't turn on
Possible failures are:
  1. Powersupply failure
  2. Motherboard failure (Check the capacitors for popped ones)
  3. Front I/O Panel
Posted on Sep 01, 2008
  • 998 Answers
SOURCE: Dell Optiplex Power-on Problem
An Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc...
Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Jan 18, 2009
  • 77 Answers
SOURCE: Computer boots up when plugged in,monitor powers down
hi there.......
it is the memory it has to be matched with the actual fsb of the cpu if its slower then it wont switch on.....
and some dell pc's wont work with 1gb sticks so accertain which ram is compatible with the motherboard
Posted on Feb 24, 2009
Zizzler
  • 61 Answers
SOURCE: i want to download dell optiplex 745 sound drivers
Hello
You can download audio driver from Dell Support page for you model.
On that page select correct Operating System, Driver Language, Category: Audio.
Best regards,
Zizzler
Posted on Apr 23, 2009
Geekman
  • 32281 Answers
SOURCE: My Dell Optiplex 745 "No Boot Device Available"
No boot device means that the computer cannot find a drive that has a operating system files and therefore cannot boot up.
This usually means that the hard drive in the computer is faulty.
You need to get a new hard drive and install Windows on the hard drive, together with the drivers for the computer's installed devices and programs to get a working computer.
Posted on Sep 07, 2009
Problem with Dell optiplex 745 desktop computer,forgat win.7pro. logon password
You will need to have a computer tech with a password recovery tool, fix your issue. Unless you have another admin user on the computer who knows their password.
Apr 21, 2014 | Dell OPTIPLEX 745 PC Desktop
I have a Dell Optiplex 745 desktop computer and now it does not work!
You have fried your power supply. If you are lucky, that is all you have done but when it blew, there is a chance it sent a surge that also damaged the motherboard or some other component.
Replace your PC heart How to install power supply in your computer
Jun 11, 2017 | Dell OPTIPLEX 745 PC Desktop
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
I boutght used optiplex 745 turn on asks 4 password i dont have
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
Locate the 3-pin CMOS password reset jumper on the system board.
Remove the jumper plug from pins 1 and 2.
Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
Replace the jumper plug on pins 1 and 2.
Feb 28, 2012 | Dell OPTIPLEX 745 PC Desktop
Dell desktop optiplex 745 it builin vga card is not responced what i do?
If you think your vga card is not responding?? just try to insert another vga card in your expansion slot.
Otherwise you mean your computer have no display first try to switch on your pc and try to hear your computer fans are all working..if it is working just try to re install your RAM and u must clean it with a cloth.
Sep 04, 2011 | Dell OPTIPLEX 745 PC Desktop
Bought a used Dell Optiplex 745 Desktop Computer. Seems to boot up okay, but no video. Want to check inside to see if any connectors are loose. How do you remove off the cover(s)?; I don't see any screws...
To remove the side of the Dell Optiplex 745 cases you need to push the release latch on the back either top or side depending on whether it is a tower or a desktop. The latch just slides back and the side will release and the cover will pop loose. The normal issue with this model is not a bad video card, it is bad capacitors on the motherboard. We repair these boards all the time for a federal prison that is located near our office. Look over this guide we have posted on our site that explains what to look for and what to do about it. http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/ The repair is easy to do if you can solder, We have 4 units in right now for repair. Check out your board, I would bet his is what your problem is.
I hope this helps, if so please rate our solution.
BuddyMc
Jan 20, 2011 | Dell OPTIPLEX 745 PC Desktop
Hook vga cord to hdtv and optiplex desk top get
Try a different display setting, for example, 1280 x 800 or 1024 x 768. Once you can see (computer) display, then move onto the best resolution which your display card support for your HDTV. Good luck..
(btw, if your dell has two vga sockets, get another vga cable. Then set your computer to a dual display mode, one for your computer and the other for HDTV. this way you will never lose your display.)
Dec 09, 2009 | Dell Computers & Internet
Dell OPTIPLEX 745 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
