Question about Olympus DM-20 Digital Voice Recorder
How to I change language to english on SME DM-40
HI all i have 2 question lol - first the language on my tv hannspree 40 inch has changed to a language i dont know i need to change it back to english and the second question is how do i get the stup
The language will be indicated in the menu--if another language other than English--use the free Google "Babel Fish" to translate words to english and then in the menu make the correction back----menu button on remote or set should take you there.
Apr 29, 2012 | Hannspree (K206-10U1-005) Television
Sony Bravia LED Restore Language settings to english
Press the Menu button and choose setup(The one that looks like a drawer). The langauge option is the first one in the setup sub menu. Select it, change it to English and press OK. Exit the menu. Thats all.
Aug 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I changed the language by mistake while navigatig the menu. I want t get back to the original English, which I could not do because all was in sme other language. How t get the original setting?
I can think of one way. In the chat menu in Google you can chat in differnet languages so you might be able to interpret the menu on you handset that way. You might also find a friend who is familiar with both the idiom and menu on your phone.
Mar 24, 2011 | Samsung SGH-T519 Cellular Phone
I am unable to record it showing lock symbol and it changed in to japaneese language so i am unable to do something pls help me
To reset the settings back to English:
1. Set the DM-10 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-10 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-10 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Download all files first before because this will reset/format your DM-10
Feb 28, 2011 | Olympus DM-10 Digital Voice Recorder
The language is unknowinglychanged from English to
First check www,samsung.com and look for firmware updates for your model and follow the instructions to a tee.
If that does not help then the Main bd is bad.
Apr 10, 2010 | Samsung LA40R81BDX 40 in. LCD TV
DM-10 reverted to japanese
Jan 09, 2009 | Olympus DM-10 Handheld Digital Voice...
Dm-20 displays Chinese
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
Jan 08, 2009 | Olympus DM-20 Digital Voice Recorder
How do I Change from default language back to English?
Apr 07, 2007 | Olympus DM-20 Digital Voice Recorder
I received this response from the european Olypus support group :- Turn recorder on - Press STOP, FOLDER and MENU buttons and hold all of them for about 3 seconds or until display changes - then press PLAY button and that resets the recorder back to English. Olympus Digital Imaging Support Group
Aug 31, 2006 | Olympus DM-20 Digital Voice Recorder
Olympus DM-20 Digital Voice Recorder Logo
41 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
