Question about Casio Exilim EX-V7 Digital Camera
Camara stabilizer is not available appears on screen
3 Suggested Answers
SOURCE: When i slide to take a pic it says that camara
I have a Casio Exilim EX-V7 and I had the same Camera Stabilizer is not available problem, the firmware on my camera was 1.01 (hold down the menu key while sliding the cover open, keep holding until your firmware version displayed) From Casio.com, I downloaded the new firmware 1.03 (you need to register your serial number to do this (put in your serial number ONLY NUMBERS no letters from the bottom of the camera). Run the file you download to extract the bin file needed for the firmware. Connect the camera to your computer. When the folder opens put bin file into that location. MAKE SURE THE CAMERA BATTERY IS CHARGED. Hold down the shutter button (on top) at the same time press and hold the menu button then whil holding those two open the lens cover to power on the camera. It will prompt you on the screen to do the rest. It upgrades very quickly.
Mine still shows the Stabilizer error at startup however, it doesn't turn off and i can take pictures. Have fun and good luck.
Steve
Posted on Oct 25, 2009
  • 415 Answers
SOURCE: Camera Stabilizer not available
make sure that you are using the right scene mode. for example if you are using night mode then maybe the stabilizer is not available for tha mode.
try changing modes to see if it becomes available
Posted on Jan 25, 2010
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
What should i do to my CASIO DIGICAM EXILIM EX-V7 because it always appear on the screen CAMERA STABILIZER IS NOT AVAILABLE..It's unusable
Perhaps there is a problem with your camera hardware. You need to get that changed to use it.Take it to a repairing shop and get it repaired.
Apr 02, 2011 | Cameras
Jan 25, 2010 | Casio Exilim EX-V7 Digital Camera
When i slide to take a pic it says that camara stabilizer is not available.
Steve
Jul 02, 2009 | Casio Exilim EX-V7 Digital Camera
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Camera stabilizer is not available
The problem of my Camera is Stabilizer not Available. please fix this problem..
Aug 27, 2008 | Casio Exilim EX-V7 Digital Camera
Camera Stabilizer
You should never install a firmware upgrade when you have a stabilizer error. That error message is something that needs to be sent into repairs to have fixed. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2, and most of those are covered by warranty.
Mar 29, 2008 | Casio Exilim EX-V7 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Black screen when camara is in photo mode
anyone else had this? or know what to do. whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
Jun 24, 2006 | Fuji FinePix S304 Digital Camera
Casio Exilim EX-V7 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
