Question about Miele DA 289-4 Kitchen Hood
On light continually flashing when switced on fan not working
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
This is a programme mode but just can't put my finger on it this second. It isn't actually a fault. Try holding your finger on the on / off switch for 5 seconds.
Posted on May 06, 2017
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Took filter out to clean pressed contol switches to cancel red cleaning light but think I pressed wrong switches on control continually flashing when switced on and fan not working
You have entered a programming mode. BTW, the light is a time activated thing. There is no sensor for blocked filters. It is just there to remind people that don't bother clean them regularly. Try holding the on / off button in for 5 seconds. With out knowing what you actually did, it is a bit of a trial.
Feb 10, 2014 | Miele DA 289-4 Kitchen Hood
Hitachi p50h401 the power light keeps flashing
If you have a flashing red light, try this first: The flashing red light is, according to the Hitachi service manual, an indication of exactly one problem. It is that the fan (internal, blows air over the power supply heat sinks) has failed. In my case, it failed by continuing to spin (very confusing), but put out a signal (3V on the white wire of the fan harness) that it has failed (I had to look up the data sheet on the fan to figure this out). A new fan from Arrow $10 fixed the problem. If you suspect your fan, spinning or not, you can safely short the white to the black wire to see if your TV remains on after being turned on (solid red light), and then try turning your TV on (blue light) to see if it works.
Oct 17, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Fan blows but no heat. Green light flashes four times
If the fan blows and green light flashes. When the green light is fix, it means the time is set to start your heat pump. Check your electrical control and wiring for any damages including the terminal lugs, capacitor, or relay. Check also if the thermostat is working. If your heating comes from heating coils, check continuity of the heater wire including the overload. Replace any defective parts.
Sep 01, 2011 | Heating & Cooling
We're wiring a 3 way fan switch. We have black (lead), green, gray and brown wires. We know where the black wire goes but were do the other ones go?
the wire from the switces usually correspond to the harness. the black is the feed (hot) green is ground or bare copper wire the gray is nuetral or white wire.the browns are switch wires,
Jun 12, 2011 | Westinghouse Electric Ceiling Fan 3-way...
Quarum Q63605-58 ceiling fan- I cannot figure out how to reverse the fan
if you look under the blades there is a round canoppy there is a litlle black switc just flip it the opposite and it should work
Jan 14, 2011 | Heating & Cooling
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Wash light flashes
Hi LIANNEshaun,
I'm Harvey the Master Plumber.
Your problem is: you switch on dishwasher and it seems to start then light goes onto wash and the machine stops and green light flashes
Could we have the make, model and year please?
Feel free contact me again!
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Miele DA 289-4 Kitchen Hood Logo
79 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Steve
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
