Question about Creative Labs Audio Players & Recorders
SBS A300 's adopter has become damaged. From where i can buy a new adopter.
SBS A300 Adopter
  • 1,511 Answers
Go on line to Creative Labs, parts department and input the data printed on the adapter where required. Or type the Model Number in the command line of Bing and they will direct you to a source within seconds.
Posted on Feb 10, 2014
Hi first i connected the xbox with the given xbox power spply adopter later from that smoke had came out and i immediately switched off so now my xbox power supply adopter was spoiled or not it means i...
The first thing I would do, is find a buddy with another power supply and see if it was not the system. If your system is still under warenty, they will fix it for free. The power supply is way cheaper to purchase than a whole system, so you really need to make sure you're not needlessly buying things.
Apr 14, 2014 | Microsoft Xbox 360 Console
No power,power indicator led won't lit.
Hello
That means that you have a problem with the power of your unit check the power adopter by a voltmeter if there is a 5 volts output if no voltage detected check the power source where your adopter is plugged. If there is an AC output on the outlet, check the output wire of the adopter. If the wire of the adopter have no problem on the connection check the socket where the output of the adopter is being inserted try to squeeze it while the adopter is being plugged to the AC. If the problem is still there look at the sticker of your unit if under warranty, if under warranty return it to the store where you buy it to avail the free service warranty. But if not under warranty you can fix it if you have a little knowledge in electronics. Because there is an internal damage on your unit either the power adopter of the unit or inside the unit.
If the adopter is only the problem you can open it by removing the one screw on the back of the adopter. See to it that the adopter is unplugged, then check the fuse of the adopter it is a small tube like component you can test it by a multi tester if there is a continuity it means the fuse is not busted but if no continuity it means you have to replace it with the same value. The second one is if there is a bulge capacitor. It means that if there is a capacitor that change there original shape, sometimes it blow sometime it just pop on the top of. Replace if there is a capacitor with look like that, Replace it with the value in farrad and in volts.
Hope this solution will help you
Sep 02, 2011 | KWorld TV BOX KWORLD|KW-SA220 1080I RTL TV...
Computer cannot connect to the internet
You should check the cable to see if it is connect properly to the computer and to the modem,you should try using another cable because that one may be faulty.You should check to see if the LAN drivers are missing, you can do this by clicking the start button, click on RUN and type devmgmt.msc if you see a yellow question mark at the network adopter,that would mean you need to install the drivers for the network adopter.You can get the network adopter choosing your model of computer from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=82702&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us and follow the steps provided. If you still see the problem you would need to replace the network adopter,you can buy one at any computer store and fit it firmly in a PCI slot in your computer.
Aug 16, 2010 | Compaq Computers & Internet
Wont operate on battery
Hello bzbeeus,
I'm afraid to tell you that you will need a new ac adaptor. Your ferritt chewing threw your cord did not blow any kind of fuse (besides the fact that there isn't one).
Basically you can search on amazon.com they always have great deals and price comparisons on things of this nature.
Hope this helps steer you in the right direction, thank you for choosing Fixya!
Jul 18, 2009 | Dell Latitude D600 Notebook
Laptop battery terminal problem
check the power setting in control panel > power options, running from battery may be disabled
Jun 08, 2009 | Matsonic MS9337c Motherboard
Memory card
yes its different from other brand like nokia,sony ericsson,etc..but some of motorola model/brand are compatible but they had a universal adopter that you can buy....i hope it can helps ^_^
Sep 28, 2008 | Motorola Mobility MOTOROKR E6
Power adopter of microtek scanmaker 3840
any kind of adoptor with 12volts output 50/60hz will do...
Jan 03, 2008 | Microtek scanmaker 3840
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
