Question about Barbie Watches
Lojra me barbi te bukura
Muti
DOES THE HOLE HAVE TO BE BLOCKED ON THE REGULATOR AND HOSE ASSEMBLY ON THE 5 BURNER DGFS10SSP 2015?
The hole you are referring to is on the gas supply side of the regulator I guess. It is a very small hole and looks like it is blocked but is probably open. It lets high pressure gas into the regulator which reduces the gas pressure before sending it to the burners. The best way to test it is open and the regulators is working is to disconnect the hose to the burners and place it into a can of water. Bubbles means it is working.
Jun 22, 2016 | Barbie Pet Doctor Doll w Cat Dog...
What do they do
time is working
Mar 03, 2015 | Barbie Watches
Barbie horse
HAVE YOU TRIED TO PUT BATTERIES IN IF NOT TRY THAT BTW TRY TO RETURN THE HORSE.
Dec 14, 2012 | Mattel Barbie Action Figure Horse 1998
Can,t get the back of my watch to seal . I put my own battery in but cant replace back on.
My best guess is that you need to have a watch press to pop the back on. Take to a local jeweler who has one and see if they can help.
Best regards. Jewel
Sep 19, 2010 | Barbie Lorus Analog Nostalgia BC0236TIN...
Where to buy it ?
Check any of the links below for Barbie Wrist watch:
http://www.amazon.com/Barbie-Fashion-Watch-Girls-wristwatch/dp/B00005BZE6
http://www.amazon.com/Disney-BBO805-Barbie-Wristwatch-Gift/dp/B002MW9ZA0
http://www3.shopping.com/xPO-Mattel-Fashionable-and-interchangeable-Barbie-watch-wristwatch-with-mini-backpack
Good luck
May 19, 2010 | Barbie 1190477 Wrist Watch
I got a barbie watch gift for my daugter, but i couldnot find the battery? where is it and how it work?
Of course the battery is inside and you would need to remove the case back on the watch to find it. You should have someone do it for you that has the proper tool to remove the case back and to properly remove and install the new one. Believe me, even stores can "screw it up". So you should not attempt this. Pay $5 to $10 and get an experienced person to do this for you. If you bought this new, then it should be working and you should not have to replace the battery. In that case, return it to the store or have them exchange it for another one. Hope this helps, Good Luck
Nov 17, 2009 | Barbie Lorus Analog Nostalgia BC0236TIN...
Tissot T-Touch
Hello, if u read the user's manual, there is an option to resync the hands. Goto the units mode ( Press the middle button, and then twice in the center of the screen, so that the digital display shows either 24h Cm or 12h... u get it ) Once in that press and hold the middle button for 5 seconds, until the display shows SYNCHRO. Then use te top button to adjust the minute hand and te bottom button to adjust the hour hand, and bring them both, one on top of the other, over the 12 o'clock position. Once this is set, press the middle button again. This should to the trick.
Oct 24, 2007 | Tissot T33.1.588.51 T-Touch Dial
Watches Logo
29 people viewed this question
Top Barbie Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Barbie Watch Expert? Answer questions, earn points and help others
