Question about Philips DVDR520H DVD Player/HDD
Disc problem I use the disc DVD+RW Rewritable as the manual says... But the problem is that the display says that i use wrong disc... What is the problem...Can i have an answer
2 Suggested Answers
  • 67 Answers
SOURCE: My Philips HTS3105 displays No Disc
Sounds like a compatibility issue try different brand of DVDR.
Posted on Jul 10, 2009
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
When recorded that show its record but after some time its not paly in any player even my Sony DVD cam also
try to find a rewritable media that is compatible with your player, like it can read recorded dvd disc . some dvd plyer dont have capable of reading photo cd, recorded disc, burned disc etc. maybe your player is the one like that.
Feb 02, 2011 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
Creating a data cd
Data discs won't play in a DVD player or display on a TV.
Why would you want to "watch" a word file anyway???
Apr 09, 2010 | Teac CD-Rewritable W28E CD-RW Burner
I can't get it to override a information on a disc or add more video to disc
There are several types of DVD disks:
* DVD-R -- "write-once-read-many"
* DVD+R -- "write-once-read-many"
* DVD-R DL -- "write-once-read-many" (dual-layer)
* DVD+R DL -- "write-once-read-many" (dual-layer)
* DVD-RW -- "quick-erase-then-rewritable"
* DVD+RW -- "quick-erase-then-rewritable"
So, there is no way to "add-later" -- once you have written, the disk is "closed" to further writing.
The 'RW' disks can be quick-erased (takes about 60 seconds) and then you can start again to write, but that still is not the same as "add more video".
Mar 01, 2010 | JVC Everio Share Station DVD Burner Burner
Dvd-r or dvd+r or dvd-rw or dvd+rw
dvd-r Does not allow for menus
dvd+r Allows for menus
dvd-rw Rewritable disc that doesn't allow menus
dvd+rw Rewritable disc allows for menus
Sep 29, 2009 | Compaq (200356-001)...
How do you use the combo I tried but I did it wrong it says wrong dvd and it is a rewritable one Thamks
The Go Video VR 4940 can only record to DVD -R and DVD -RW discs. It cannot record to +R or +RW discs. It can play back many types of discs, but can only record to the -R and -RW ones.
JFFields
Jan 16, 2009 | GoVideo VR4940 DVD Player/VCR
I cant get DVD RW disk to work in ny dvd recorder DVDR5500
This player only accepts DVD+RW rewritable discs. Some players are also fussy with which brands you use. If you are using DVD+RW and it isin't working try another brand of disc.Hope this helps.
Aug 30, 2008 | Philips Televison & Video
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
My SONY DRU-810A DVD Writer doesn't work with TDK DVD+RW Disc
some dvd brands dont work with all dvd writers, so your option is to try another make, if that works ok then it's not a writer fault it is just that the media make is not compatable. if you start to see problems with all makes of disc then the writer laser is faulty and a replacement drive neccasary.
May 11, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Philips DVDR520H DVD Player/HDD Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
