Question about Icom IC-V8000
I have a low whistle coming from my icom v8000 when i transmit only on 145.170 mhg.When i put the swr meter on line it goes away.I have a flat match.
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: Icom M710 Transceiver dosen't transmit.
Hi mesquaukee,
Are you trying to connect the SCS PTC-IIpro to an Icom M710 (or M700pro) marine transceiver? If you do kindly refer on the information below:
The audio connections are the same as the PTC-II/IIe, the radio-control connection is specific to the IIpro.
Audio connections:
PTC-IIpro Audio Icom M710 ACC(1)
(8-pin SCS DIN) (8-pin Icom DIN)
(Tx audio) Pin 1----(vio)-----Pin 4 (Mod)
(Rx audio) Pin 4----(grn)-----Pin 5 (AF out)
(PTT) Pin 3----(yel)-----Pin 3 (PTT in)
(Gnd) Pin 2----(wht)-----Pin 2 (ground)
(+12V) Pin 5----(blu)-----Pin 7 (12V out- see note)
Shell---(shield)---Shell
Notes:
1. The colors shown above are for the pigtail cable supplied with the PTC-IIpro. Check the colors with an ohmmeter, errors are possible.
2. The German-style DIN connector has a different physical pin geometry, and is not interchaneable with the US-style DIN connector used by Icom. Label the cable ends to avoid any confusion over which end goes where.
3. The PTC-IIpro has provision for an alternate 12V input on its HF audio connector. This provides a convenient way to connect power to the modem, but if the cable is particularly long then this could be a source of RF interference. Consider a separate power connection for long cables.
Remote Control:
Remote frequency-control is optional, but highly recommended when a PTC-IIpro modem is used with an Icom M710/M700pro transceiver. There are two options for connecting remote control to the radio, the recommended connection is to use the M710's 9-pin "Remote" connector (supported from Airmail ver 3.0.857 onwards). As an alternative, the 1/8" mini-phone "Clone" jack can be used, see "option 2" below.
PTC-IIpro "Control" ICOM 710 "Remote"
(13-pin DIN) (DB-9P 9-pin male)
Pin 3 (yellow) -------- NMI+ 5
Pin 8 (red) ----------- NMO+ 7
Pin 13 (orange) ---+--- NMI- 6 (see note)
+--- GND 9
Shell ----(shield)----- Shell
Note: Add a jumper between pin 6 and 9 on the 9-pin connector, so that the (orange) ground wire connects to both pins. Also make sure that unused wires are carefully insulated, short-circuits can damage the radio or modem.
Radio Settings:
In order to use the NMEA interface, it must first be selected using the front-panel "Set Mode" functions (turn power on while holding down the "Func" and "1" buttons-- or "Ent" and "1" for the 700 pro). Select the "REMT-IF" (remote interface) setting and change it "d-Sub" (or "RS-232" on some models). Also check that the "REMT-ID" setting matches Airmail's "AIcom Addr" setting).
AirMail Options Settings:
Modem (TNC) connection:
Modem type: PTC-IIpro
Comm port: COM1 or as appropriate
Baud rate: 38400 or 57600
Show link messages: no check
Ignore CTS: no check
Audio Tones:
Center Frequency: 1500
Check "USB"
Check "Marine (FSK dial=center)"
Amplitudes: as appropriate, start with 130/170
Radio connection:
Check "Direct using PTC-II control port"
RS-232: Checked (this is important!)
Radio type: "Icom-M710" (select appropriate model)
Baud: 4800
Icom Addr (hex): 01 for M710, 02 for M700pro, or 03 for M710RT (must match radio's REMT-ID setting)
Dial offset: 00
Note: Entering the radio modes with the "Modes" button is no longer required.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 14, 2011
How do you recalibrate the SWR meter in an Icom 706Mkiig radio. I changed the filter board and it seems off now.
You will need the service manual to be able to do this and you will also need to purchase a 150 ohm carbon film resistor (no wire wound resistors) to simulate a 3:1 SWR to reset the onboard auto tuner base line for SWR. I believe you may find a service manual on BAMBA's website to download for free. The auto tuner is factory set to work up to a 3:1 SWR before it gives up trying to match the antenna. So, this is a resistor you will need or make up a 150 ohm load using a combo of resistors as long as they are not wire wound types. 73, Dennis
Mar 31, 2017 | Icom Radio Communications
How do I adjust my swr on cOnex 3300
SWR is adjusted at the antenna. I am not sure how familiar you are with SWR so forgive me if I repeat something you already know.
The first thing you need is a way to measure SWR, an SWR meter. Theses can be found on ebay or elsewhere. The SWR meter attaches to the radio with a short coax cable of about 2 feet or less. The other connector on the SWR meter goes to the antenna coax. Once hooked up you should see a switch that reads forward and reverse or abbreviations of such. Place it in forward position. Now there should be a knob adjustment that you can turn. You key the radio, meaning press the mic button to transmit. While holding the button and transmitting adjust the knob on the SWR meter until it reads exactly full scale. After you have done that flip the switch to reverse while transmitting and read the value shown. At the low end it should read 1,2,3,4 etc. If you are lucky it should be between 1 and 2. If so say it is 1.5 then you can say your SWR is 1.5:1 which is ok. If you had a 2.0:1 Swr you would be losing only 11% of your power, giving you 89% still going out the antenna. 3.0:1 would be a 25% loss and so on. Really not that big of a deal. But some radios need better than that or they will reduce their power slightly or not at all if its too far off meaning something is terribly wrong with the coax or antenna. If its less than 2.0:1 I would just leave it alone. But if you find in reverse that the meter goes way over to the right, then you need to find the problem. a shorted or open coax or same with antenna. If you are ok with swr but just want to play and dial it in better than all you do is raise and lower the antenna ever so slightly by loosing the set screw at the base of the antenna. Make sure you mark the old spot in case you need to return it back to that position. Now on other antennas there will be an adjustment at the very top of the antenna that can be turned. Like a carbon ferrite type of screw inside the antenna. This is of course for a short antenna. If you are using a 1/4 wave whip which is the best to use in my opinion kit is around 102 inches long. gives you more range and better receive. If you drive a truck then that is out of the question. But somthing that is overlooked is the fact when you take the meter out after you are done checking the SWR. Your SWR will change and wont be what you just had with the meter in line. So leave meter inline or do this: Most meters have a field strength option. What you do is attach a small wire antenna to the SWR box where there is a small screw hole for it to attach. If you dont have an antenna make one out of a bout a 10 inch stiff copper wire. In this test you will not be hooked up to the cb radio with your SWR meter. Hook you cb back up just to the antenna coax to your antenna. Key the mic again to transmit, tape it into place to hold it there. Now put the swr meter on forward or field strength if if has a selection for that. Now walk away from your antenna about 10 feet so with the adjustment turned up all the way for full meter deflection on the swr meter you should see it get stronger as you get closer to the antenna or weaker as you move away from it. You are actually seeing the power coming from the antenna. You can now set you meter on something away from your antenna where you can see the meter but dont have to hold it. Note the reading. Go back to the cb and stop it from transmitting. You can now make adjustments to your antenna then transmit again and look at the meter. Did it go up or down? Ideally you want maximum meter deflection for maximum power. I f you hook up the swr meter again with cables and it shows something other than 1:1 doesn't matter because like I said once you take the meter out or put it in the swr changes. you are changing the length of the coax. What matters is maximum power right? That's what most people try to achieve by adjusting swr. But like I said on that too, really you wont be able to tell the difference on the receiving end of somebody elses CB when you are talking. To be real you would have to 4 times your power in order for the s meter to go up one s unit on your buddys receiver while you are transmitting. So don't get lost in in all the CB hype of other peoples theory of how important swr is. Your radio is looking for about 50 Ohms of value to work as it should. a 2.0:1 swr would say that it is seeing either 25 Ohms or 100 Ohms. The coax cable should be rated at 50 Ohms meaning if there is 50 Ohms t the other end the coax will be 50 Ohms if you were to measure it at any point on the line. But if there is anything different, then these rf waves travel from your radio to the antenna where if not 50 Ohms will not consume or output all the power at the antenna and the result is waves not going out will come back toward your radio, hence the reverse setting where you are seeing this happen. This can be so involved and yes just because there might be 50 Ohms at the antenna doesn't mean the antenna is resonating at the right frequency. This is why the field strength is important too. The value where the coax meets the antenna ideally should be 50 Ohms but it can be anything because of the design and length of the antenna. So you see you can be moving the antenna in and out to make it 50 Ohms but at the same time you are changing the frequency it wants to emit the best too which could be different. So to say the swr can be off a little if you get more power coming out of the antenna. Sorry for such length but hoping it makes more sense for you.
Jul 17, 2016 | Radio Communications
My icom v8000 says off when I transmit how do I fix this
Hi
This sounds very much to me like a power supply problem.
If I understand your question correctly, the radio will turn on but when transmitting it shuts itself shuts off. This is usually caused by a poor connection to your battery. Although it is possible to show 12v using a voltmeter, there may not be enough connection when putting the circuit under load. (25 watts is a considerable load)
I would inspect both positive and negative connections (pay particular attention to the crimped lugs) , clean and lubricate them and give it another shot.
Here is a link to Trojan battery explaining in detail the importance of clean battery terminals.
Hope this helps you out.
-Steve
http://www.trojanbattery.com/pdf/WP_BatteryCableGuide_0512.pdf
Mar 09, 2015 | Icom IC-V8000
Hallo iam using a icom 718 on 28mhz up to 14mhz have a problem of a high swr reading but the antenna is fine then power drop away
Check the feedline to the antenna, and the antenna itself. High SWR means that power is being reflected back from the antenna. A good discussion of SWR may be found here: http://www.hamuniverse.com/wc7iswr.html
If you antenna is designed for 10M and your are trying to transmit 20M on it, there will be a significant mis-match. You may want to look at installing a better broadband antenna, such as an OCFD that will operate better on multiple bands.
Feb 18, 2015 | Icom IC-718 Base radio, HF, 100W
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
I just need to know how to use it for conversations and what every turn dial means.
you need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 12, 2010 | Cobra 29 LTD CB Radio
C.b. is transmitting weak.
If it is low audio, it could be a problem with your mic or his speaker. If your signal is low, I suspect it is likely to be an issue with your antenna system.
The antenna systen consists of the feedline or coax cable and the antenna. The feedline should be inspected for evidence of damage from being pinched, cut or water entry over its entire length., Remove, replace or reposition to prevent the cable from becoming damaged in any way.
The antenna itself should ideally be located at the highest point on the vehicle. Further, it should be secured to firmly into the metal parts of vehicle - preferable to a large, flat surface. The surface should be grounded.
Matching the antenna system for lowest SWR to the transmitter is required. SWR is a ratio of "power out" of the transmitter to "power that is reflected back" from the antenna. Ideal theoretical ratio or "match" is 1:1 (or one to one). Real-life is more like 1.1:1 (one point one to one). Most transmitters are perfectly happy with a match (or mismatch as the case may be) of 1.5:1 and some even up to 2.0:1. More than this is asking for trouble. A mismatched antenna system can cause RFI and failure of the output final transistors.
Matching or lowering the SWR of a radio to an antenna system requires that an SWR meter be installed between the antenna coax or cable and the transmitter's antenna connection point. There are two types of meters - dual needle and single needle. The dual type is more expensive, but easier to work. The meter must be capable of working on the frequency it is to used on. This means if it is marked as a 400 - 512 Mhz or UHF type, it will probably not be accurate on 27 Mhz or HF.
Once the meter has been installed, transmit the highest frequency or channel and take readings. Do the same at the lowest and a middle frequencies and record findings. Physically adjust the length of the antenna whip up or down in the antenna base - by no more than 1/4" inch (for 27MHz CB frequencies) and check again. After a few tries in one direction, you should begin to see how shortening or lengthening the whip changes the SWR of the system. Once set correctly, the middle frequency will have the lowest SWR value while the lowest and highest frequencies will have pretty close to equal, but higher SWR values. It would look something like this: Ch1 = 1.6:1 Ch 20 = 1.2:1 Ch40= 1.6:1 Of course, if Ch1 = 1.7:1 and Ch 40 = 1.6:1 that would be fine, too. Once completed, the SWR meter can be removed from the antenna system.
A poorly matched antenna system can cause permanent damage to the transmitter, if not corrected.
Sep 21, 2009 | Cobra Radio Communications
Radio will transmit some of the time
THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Dec 08, 2008 | Galaxy Radios DX-93T Base CB Radio
Matching c b antenna with c b radio
here is some information that will help you test SWR with an inline watt meter. To get proper results you need to use an inline watt meter. Here is a really good site you can go to for help www.cbradiotalk.com
Equipment needed: SWR meter, short jumper coax 3 foot.
midland.jpgProcedure: The SWR meter needs to be placed in line between the antenna and the CB. Connect the antenna (normally connected to the back of the CB ) to the connector marked "Antenna" or "Ant" on your SWR Meter. Connect one end of the short jumper coax to the "transmit" or "Xmit" on the SWR meter. Connect the other end of your jumper coax to the CB.
Assuming you have a standard SWR meter the switches should read as follows: REF or SWR, FWD, and there should be a slide switch marked "set" or "Adjust". If different consult your meter's owners manual.
With the radio on the lowest channel (1 on CB) and the SWR meters switch in the Forward (FWD) position, depress the transmit switch (key up) located on the microphone. While holding the unit in this transmit mode, adjust the meter needle to the set position using the Set or Adjust knob on the meter. As soon as the needle is in alignment with the corresponding mark on the meter face, flip the switch to the Reference (REF) position. The meter is now showing your SWR on channel one. Note the value and quickly release the microphone switch. Record this reading.
Repeat the previous step on channels 19 and 40.
How to read your results: If SWR on channels 1, 19 & 40 is below 2.0, your radio can be operated safely.
If SWR on all channels is above 2.0 but not in the "red zone" (normally over 3.0), you may be experiencing coaxial cable reaction (bad quality, wrong length, etc.), insufficient ground plane, or have an ungrounded antenna mount.
If SWR is in the "red zone" on all channels, you probably have an electrical short in your coax connectors, or your mounting stud was installed incorrectly and is shorted. Do not operate your radio until the problem is found, serious damage can occur to your radio.
If SWR on the lowest channel is higher than it is on the highest channel, your antenna system appears to be electrically short. Your antenna length may need to be increased.
If the SWR on channel 40 is greater than that on channel 1, your antenna is considered to be "LONG" and reduction of physical height and/or conductor length will correct this situation.
Aug 01, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Icom IC-V8000 Logo
46 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Lawrence Oravetz
Are you an Icom Boating Expert? Answer questions, earn points and help others
