Question about Mitutoyo 543 452B Electronic Digital Indicator
MITUTOYO 543-558-1 INDICATOR LOCKED UP. HOW TO UNLOCK IT?
I need operating instructions for the mitutoyo 543-392B guage
KEY : DATA ON/OFF ==> Switching ON/OF
: SET ==> Enter the origin setting ( switch to the ABS system)
==> Enter the tolerance limit setting
==> Enter the selected mode,release the hold
: MODE ==> Select measurement modes
==> Return to the normal mode
Sep 29, 2012 | Mitutoyo 543-392B Electronic...
I have mitutoyo digamatic indicators that the numbers jump around
Why does everything have to be digital?
I love the STANLEY 12 ft.
Dec 29, 2010 | Mitutoyo Measuring Tools & Sensors
I need a replacement thimble lock for a mitutoyo 6-12" outside micrometer(104-138 s/n#1080588).
i image the 6 - 12" is a fairly expensive set. you could buy the 0-1" which has the same thimble lock. i have one at home. and switch them out. can be bought $100 or less brand new. or search for an ebay bargain.ive never heard of the thimble lock go missing or break before. its doubtful mititoyo supplies replacement parts for mics.
Mar 31, 2010 | Mitutoyo Measuring Tools & Sensors
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
Mar 28, 2010 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
Im looking for the instructions manual for Mitutoyo 543-271B
For any manual contact Mitutoyo nearest office , they are professional and will help you.
Feb 13, 2010 | Measuring Tools & Sensors
Adjusting the angle of the contact point on a Mitutoyo 513-402
By simply pushing it (the contact point), it may be stiff to start but should ease up over time. Remember if your doing precision work (0.001mm or seconds of a degree) changing this original position will affect your reading so refer to booklet within original packaging or visit mitutoyo website's (Japan, USA, UK) between them they have most instructions available it's just a question of finding it, Good Luck.
May 09, 2009 | Mitutoyo Dial Indicator-Graduations:0....
Mitutoyo 543 452B Electronic Digital Indicator Logo
245 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
