Question about Arctic Cat 2010 CrossFire 8 Sno Pro
Run out of gas fill tank 3/4 with fresh gas won't start doesn't seem to be getting gas.
    Welcome Back:
    Visited the website for 2 consecutive days.
You will need to make the fuel pump work to put fue back into the full system,make sure battery is fully charged
Posted on Feb 10, 2014
Run out of gas and put some watery gas in the tank, it cut off 3mins later
Just plain silly. Remove gas tank, drain and dry. Replace fuel filter. Fill gas tank with 5 gallons of fresh gas. Add a bottle of water remover to tank then start and drive. Good luck.
Aug 21, 2013 | Toyota Cars & Trucks
Hard start cold
Ensure gas tank only has fresh gas with Stabile. Replace spark plug and air filter. Fill oil. 30w.Ensure primer bulb is not cracked.
May 21, 2013 | Toro Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starts but wont stay running
Try filling the tank and try it.
Jul 09, 2012 | Garden
2001 chevy malibu. I filled up with gas this morning and didn't get very far and it died. Won't start back up. What could it be?
Hello! I'm not so certain that the filling of the tank and the fact that the engine died and won't start are related...Lets get a little background...Has the car been running poorly; Or was everything in tip top shape, and after filling the tank it quit? Is the Check Engine Light on now? Any idea how many gallons you pumped in; And the octane you used? And lastly, was it an often used gas station?
Guru..............Saailer
Sep 27, 2011 | Cars & Trucks
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
My HD III 2 stroke motorcycle doesn;t work properly. it start ,but not run the way it use before. there is no gas flowing from the gas tank. but when i open the carburator and let it fill it chamber, i...
carbs probly need an overhaul--bike is 70s iron--the fawcett shud be inspected too--get urself a manual today for rebuild procedures-----------I miss that ol whine and the blue smoke!
Jul 15, 2011 | kawasaki Mach III H 1D Motorcycles
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
Lawn tractor won,t start. gas in carb and it will run until thats gone. seems to pump gas fine. checked plugs. got a little water in gas tank. what do I check/clean now/
If there's water in the tank, you should drain it. Disconnect the fuel line and dump the water. While you're at it check the fuel filter, and replace it if it's dirty. Use some compressed air to blow through the gas lines and hook them back up. Put fresh gas in and see if that fixes it.
Jun 09, 2010 | Craftsman Garden
Arctic Cat 2010 CrossFire 8 Sno Pro Logo
310 people viewed this question
Top Arctic Cat Winter Sports Experts
ray gallant
 steve
steve
rhodesworks
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
