Question about Dell G2210 22 inch LCD Monitor
How to open a dell g2210
Can you open these units easily?
2 Suggested Answers
  • 2841 Answers
SOURCE: I'm using the laptop with
Let it go ahead and enter Safe Mode. Then restart the computer and it will start normally.
Posted on May 23, 2011
I work for Monash Univiersity Clayton Australia, We currently have a large contract with Dell. I have an issue with a 24 black Wide Dell LCD screen, when its connected to an output it glows blue like its...
What is the model number, 24" or 22" (G2210)?
Please read my guide on how the monitor works to get some idea what to look for.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Mar 23, 2011 | Dell G2210 22 inch LCD Monitor
The DVD tray only opens after I push the button 3 or four times. When I press the button, the tray attempts to open but seems to be blocked. Finally, after several attempts, the tray will function...
The optical unit - it's tray mechanism to be more precise - has aged and it's starting to seize. Unfixable, you will have to replace it. Luckily a new dvd unit costs less than $30 and can be bought even at Walmart. Installing it is a 10 minute job that you can do yourself easily.
Dec 28, 2010 | Dell Dimension 2400 PC Desktop
When playing "Farmville" there is a toggle switch to click on to enlarge your farm picture from the normal size. My monitor goes to complete "white out". Any suggestions?
Try changing your screen resolution in Windows. The "white out" condition is usually an indication that the image being sent is out of the range of the monitor.
Jul 13, 2010 | Dell G2210 22 inch Monitor
I plugged my laptop in today and the colors on my monitor are extremely bright and distorted. I rebooted with no improvement. Help
  • Hi, "right click on a empty area of the Desktop Screen, when the window opens, select the Personalize Icon, it should be at the bottom, in the next window, click on the "Display Settings" category. Now you'll be in the Display window for the "Monitor; by trial bases select the "Resolution," move the (arrow to the highest setting, 1366 by 768 pixels... ), after doing this click on the "Apply and OK buttons, so that the change will take effect. "You can go back a couple and do this a few times to get the right visual settings. You can also adjust the [Color], example: [16 to 32 bits], and the "Color" in the [Advanced] area by clicking on the [Color Management] button. "Any other areas "I do not "recommend making changes." Try making a note of the changes you made; just in case! Note: You may need to restart the computer, if you don't see the changes right away! "Rating the solution for its "helpfulness, is appreciated, thanks."
May 16, 2010 | Dell G2210 22 inch Monitor
Optiplex 740 is crashing, i.e. no response to mouse/kb
I would open the case and look for popped capacitors, you can see them easily on the 740. make sure the caps are not swelling and popping. If they are under warranty, CALL DELL!!!!!!!!! If they are not under warranty, Ask dell about extended warranty availability. If you get the warranty, you can get dell to replace the boards or send a tech (like me) to replace the board on-site. If you ever do anything with any I.T. or I.S. you NEED to get the longest strongest warranty available. It pays for itself. If warranty is not an option, then do not panic. The boards in this unit are easy to replace. make sure you specify low profile if you have the smaller unit. You'll need a phillips screwdriver, and a pair of scissors (to cut a cable-tie, NOT any cables). Popped caps are a regular occurrence in many systems, and the case on these models flips open easily, so the boards are easy to inspect as well as replace.
Jan 24, 2010 | Dell Optiplex 740 Desktop Desktop Computer...
How do yoou remove the hard drive from side of unit to replace?
It has back side in your laptop, please unlock and open screw it open easily.
Dec 04, 2009 | Dell Latitude C640 Notebook
How to install ink cartridge in printer
Lift the printer unit from under the scanner, there should be a support to hold it up while changing the cartridge. The cartridges will align them selves automatically once you open the top, so you can access them easily. The manual for you printer can be found here:
http://support.dell.com/support/edocs/systems/924/en/index.htm
Mar 06, 2009 | Dell 924 All-in-One InkJet Printer
Dvd writer for dell gx270 mini tower
If you can think and look logically, you will be able to replace your current drive with a standard notebook drive, mostly called slimline.
open the case by pressing the two knobs at the side and lift it upwards. The unit clicks out easily, the removal of the flat cable and power connector needs a bit of patience, and you have to unscrew the drive from the bracket after that. I think you can get a drive for some $50,-5015338.jpg
Apr 15, 2008 | Computers & Internet
Dell G2210 22 inch LCD Monitor Logo
14 people viewed this question
Alun Cox
