49.4c18 error code on hp laser jet m5035 mfp
The serial number for this printer is CNBXB15042
4 Suggested Answers
Fixe_You
  • 1800 Answers
SOURCE: my printer name is HP
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Posted on Jan 22, 2009
MUKHTAR
  • 2022 Answers
SOURCE: HP LASer jet m1319f mfp errors no entries in fax
kindly re install the printer driver software .
Posted on Jan 14, 2010
  • 5343 Answers
SOURCE: HP Laser Jet CM1312 MFP internal error 0x50
Did the Ox50 error have any additional information with it or happen only with network printing?
Frequently, this error is associated with a font being sent to the printer with the PCL 6 (printer control language). The temporary fix is to turn the printer off and then on (to clear its memory).
Next try going to the Printing preferences by right clicking on the printer in the Printers control panel. (For XP, click Start > Control Panel > Printers and Faxes. In Win7, click Start > Devices and Printers (or Start > Control Panel > Hardware and Sound > View Devices and Printers). Then right click on the LaserJet CM1312 icon and select the Printing Preferences. Go to the Advanced tab and change the Print Data Optimization option from Advanced to Optimize for Text and Vector.
If this doesn't work, uninstall the printer (right click again). Then reinstall the network printer using the PCL 5 universal printer driver. All of the drivers are available here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3558903&prodTypeId=18972&prodSeriesId=3558902&swLang=8&taskId=135&swEnvOID=4063 . The PCL 5 driver is the last one in that section.
If the printer is connected to one computer via a USB connection and then that computer is the printer server for the others, you may need to disconnect USB cable and uninstall both the universal print driver and the regular printer driver. Then reinstall them in the opposite order.
I hope this helps. Please add additional information about the error for more assistance.
(PCL 6 has some issues.)
Posted on Apr 17, 2012
Hp laserjet m5035 mfp error 49 ff04
I think you are since the dc controller only controls paper movement and nothing else. A 49 error is a firmware error and has many causes from applications, network and just defective formatter. If the errors occurs with the printer not connected to anything, then the formatter would be the logical issue if the firmware has been updated. Keep in mind having a jet direct card in the slot can cause the error, so the only true way to test is with everything removed with the exception of firmware, memory and power. Also keep in mind that if the 4250/4350 series power is derived from the lvps and not the dc controller. Also with this model the embedded jet direct card is known to occasionally have issues. When you upgrade the firmware for the formatter it also upgrades the firmware on the embedded nic card. Again the only true way to test would be to disable the embedded nic card on powerup.
Read more... HP Support document HP Support Center and HP Printer Support
Jun 27, 2014 | HP LaserJet M5035 MFP Printer
Hp laser jet m5035 mfp displayig 49.4c18 error code how
I'm having problem with this error code 49.4 c18 on my hp laserjet m 5035mfp printer.Can any body he in solving this problem ?
Feb 10, 2014 | Intuit QuickBooks Pro 2011 (License Only)
Can i scan to email with m5035
You can, but you need to configure
Sep 05, 2011 | HP® LaserJet M5035 MFP Laser...
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Error code 52.00
52.00 = laser/scanner error
1. Turn the device off, and then turn the device on.
2. Reseat the connectors between the laser/scanner and the dc controller PCA (J801 and J321).
3. Replace the laser/scanner assembly.
4. Replace the dc controller PCA.
Jul 12, 2011 | HP LaserJet M5035 MFP Printer
Laser error
You may have to replace the laser/scanner assembly or the DC Controller
Sorry
Jan 17, 2011 | HP LaserJet M5035 MFP Printer
Hp printer lj m5035 in 69.30 error
According to Hp official site,
A temporary printing error occurred.Turn the device off, and then turn the device on.
If this message persists, contact an HP-authorized service or support provider.
Goodluck
Dec 06, 2010 | HP LaserJet M5035 MFP Printer
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
Jan 22, 2009 | HP LaserJet M5035 MFP Printer
54 people viewed this question
k24674
jasbo
jasbo
