Question about Asrock Computers & Internet
My mb is not load boot - Asrock Computers & Internet
Hello. I recently bought a new motherboard, fmb-0703; and windows will not load. It starts, but does not fully load. I'm running windows 7 pro 32 bit. Bios boots, every works except windows
I could be a couple of things. If it is not loading correctly More than likely something to do with memory either motherboard ram or video ram. try a live boot cd and see if it loads like hirams boot cd with live windows. it is free. also you can the motherboard and ram and hard drive the the live cd to pinpoint hardware problems. just a thought. good luck.
Jun 01, 2015 | Intel Computers & Internet
I HAVE AN ASROCK MB,ALIVE NF6G-VSTA, BIOS PL.50.I STARTED UP.EVERYTHING GOES BUT IT READS ON SCREEN :press F11 for boot menu,and below that it reads:single channel memory mode.IT STAYS THERE and it doesn...
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Oct 28, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
I am lerning a+ &n+ and i am having mercury pc but it is problom to me to boot or formet the drivers and i want to update the winxp ti win 7 some time the dv d players will not function with win...
Hi, you can download drivers here:
http://www.mercury-pc.com/downloads_list.php?productid=510
Please unzip the file before installation.
Your mainboard is too old to run windows 7 as it is 10 years old.
There is no drivers for that operating system anyway.
Consider to buy a newer pc compatible with windows 7.
Sep 01, 2011 | Mercury KVM266PM-U (KVM266PMUD1600)...
Win Me will not Boot after load. Win 98 will not Boot either. Says not enough memory ???? 2 Gig Memory PC3200-GA-8ipe1000-g Gigabyte MB
Try just using 512Mb of memory or less as there was a bug in Me and 9x that produced that error if you had more than 512 Mb of ram.
Jul 18, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Trouble recognizing processor, it says after I turn the computer on. then there are two choices : F1 - enter setup menu F2 - load defaults What should I do to fix this. All...
Press F2 and load setup defaults. See if the system boots.
On the other hand if you are familiar with what is installed on the motherboard you can press F1 and go through each bios setting. A so called authorized person wouldn't remove devices from the motherboard just to do a cleaning and should have booted the system after cleaning the system to make sure the MB functions correctly. You're MB is not that old? Produced in 2009. You have two options. With the manual in hand press F1 and go through each bios setting or take it back to the person who cleaned the MB and make them correct the bios settings so the MB boots correctly. I can only guess that the MB booted even if it was dirty/dusty. If this is not the case let me know.
Mike
Apr 22, 2010 | ASUS M2N68-AM SE2 Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Memory problem!
You've changed the hardware. Change it back. Go into the bios using the hot key in boot. Then go to exit and select load setup defaults that might fix it.
Apr 11, 2009 | Computers & Internet
Can onboard LAN in 661GX-M MB load OS from net?
Check in the bios settings if there is any LAN Boot ROM option. If yes then enable it. Now you will be able to boot from LAN provided there is Server running which supports PXE
Nov 25, 2008 | EliteGroup 661GX/800-M (661GX800M7)...
Motherboard won't boot
u can go to ur mb bios nd check ur processor setting.may be 845gvsr not support intel crl processor.u can give load bios default from ur bios press F6 or F7,
Sep 19, 2008 | Intel D845GVSR Motherboard
Not able to install RAM > 512 MB
Try to run a system repair.
Jul 14, 2008 | ASUS K8S-MX Motherboard
Computers & Internet Logo
14 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
