Question about Samsung Televison & Video
Samsung tv power board capacitors replaement - Samsung Televison & Video
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 304 Answers
SOURCE: I have a Samsung LNS3251D 32-Inch LCD HDTV , that
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Posted on Apr 16, 2010
SOURCE: power light comes on and clicking is heard but no
your problem is more a defective y board with y buffer boards one of them is short
Posted on Oct 26, 2010
  • 354 Answers
SOURCE: What are the uf values
Caps are usually labeled on the side I've never seen one that isn't.
Posted on Mar 28, 2011
  • 127 Answers
SOURCE: Samsung TV Model LA40A650A1M back light intermittently strobeing
You can't see if a cap is good or bad jus looking at them they have to be measured>They loose their capacitance because they dry overtime.
I do sugest that you replace you power supply module or replace all caps.Possibily you may have a broken line in the PCB
Posted on Nov 01, 2012
I would really appreciate help fixing a clicking relay non powering hp s5303 samsung model tv.
If you're TV is under warranty call the Samsung.co.
If not than open the back of the TV and look at the motherboard and the power board for blown capacitor's swollen or broken off and replace those capacitor's you can use the same power capacitor or a higher power capacitor.
Nov 15, 2017 | Samsung Televison & Video
Why isnt my samsung tv powering on?
usually with samsung tv's they use 10 volt capacitors on a 12 volt circuit board , most definatly one of the capacitors has bulged or popped on the power board if you do not know what a bulging capacitor looks like please google a pic of it then take the back of your tv and check the power board for bad capacitors
Aug 14, 2014 | LG 42LC2D 42 in. LCD HDTV
Samsung blown capacitors
Hello Chuck,
Before you replace the capacitors on the power supply board you need to check with Samsung. Your TV model falls under the class action lawsuit settlement and Samsung has agree to repair any TVs with faulty capacitors on the power supply board that were affected. You can get full details on the settlement here:
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
This settlement covers any listed unit for 18months starting Mar 2 2012.
BuddyMc
Jul 27, 2012 | Samsung LNT4665FX 48 in. LCD TV
14 month old samsung 32in 530 series lcd tv will turn on fine, then after a few minutes start turning on and off repeatedly for ever...until i pull the power. What do i do, call samsung?
its possibly dry joints on the power supply-the heat generated causes the solder to crack,and when warm creates a "crater" on the affected joint and expands with heat,and loses contact until cool.(retraction).should be easy if you are handy with a soldering iron!.failing that,take it to a repair shop as its out of warranty,and samsung will not want to know! (unless you got extended warranty,of course!)
good luck,steve
Sep 12, 2011 | Samsung LN32C530 32 in. TV
My Samsung HDTV takes almost a half hour to turn on. I push the on/off button and nothing seems to happen. I do have the TV connected to cable but even when I use the Samsung remote or the button on the...
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
Aug 19, 2011 | Samsung LN-S4041D 40 in. LCD HDTV
My samsung ln52a650 blew a fuse during normal operation. one second it worked the next... nothing. popped her open and couldn't find any damage/arc/flash.... exploded parts. i hear this is a common...
U have all the tools and understanding basic electronic and also can do basic soldering?Yes.The tv power supply board,that the board,where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors components parts.It is usally have bulges or puffing up capacitors parts indication of components capacitors parts are dying and needed replacement.Replacement for those new capacitors component parts with the same Micro ferit and the voltages of those new components capacitors parts in a higher voltages like 5 or 10 voltages higher than the old components capacitors parts u are replacing for a better heat resistance for the tv operation of the tv power supply board for later on tv use.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 08, 2011 | Samsung LN52A650A LCD TV
Hi i have a samsung 40" LCD TV wiht the clicking
Useally it 3 more,it alway on the tv power supply board.The the board,where the power a/c plug into it.Seaches the entire power supply board for dying capacitors,it alway bulges up or puffing up on it tops.By replacing all these capacitors with the same Micro Ferit and about 10 voltage rating higher for those dead capacitors for better tolorance next power supply board spike heat waves.
Jan 27, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a Samsung LN40A450 LCD TV that is only a year and a half old. I am getting no power to the tv only a consistent blinking red light and a audible clicking/beeping noise. What needs to be replaced?
I will explain how to:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.(see picture below)
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
  • Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Feb 01, 2010 | Samsung LN40A450 LCD TV
Samsung 32" can not turn on
Dear Bradleyphan,
two weeks ago I fix samsung LCD TV with the same problem and I've managed to fix it.
Feb 01, 2010 | Samsung LN32A330 32 in. LCD TV
Howdy,
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
