Question about AEG Lavamat 72640 Front Load Washer
Washing mahine stops after one minute
All light come on, door locks and starts filling for about one minute and then stops. Trying on spin only, drum does not turn and stops again after one minute. When door is open the drum seems to turn too freely suggesting a broken belt. As the machine is in a tight space, before I dismantle the units is a broken belt likely to be the cause?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Put it on the spin cycle and open the filter if it's the belt you will surely hear the motor spinning if not then it's not the belt
Posted on Feb 10, 2014
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Washing machine door lock problem
Just try to check the door latch device. Be sure that the latch is not bound or sticking in any way .This problem with a lot of machines and it almost always was the door lock latch assembly. It has a switch inside it that pauses or stops the cycle if the door is not closed properly, when this switch malfunctions then it will pause or stop the cycle repeatedly; just from the small movement of the wash cycle. The door will actually be shut all the way and the lock may be on. You must replaced this switch so it works normal again..
Just click for the spare parts site link;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
  • 3 Answers
SOURCE: Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
it is like that because you can **** a ****
Posted on Feb 16, 2009
  • 500 Answers
SOURCE: I have a AEG lavamat
Could be that the Inner Drum Spindle is broken, this is a 3 arm spider-ish bracket that holds the inner drum. To test this theory, see if you can lift the inner drum up & down from the door side, you will be able to feel if it is broken.
Hope this helps.
* If you found this solution helpful, please vote positively.
Posted on Feb 17, 2011
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
When i put the wash cycle on it goes and does fill up with water, but then when comes to spin cycle it stops agitating and starts beeping constantly with the light on where the "lid locked" icon is.. When...
Hi Ellie,Just read your posting.Now does your machine drain most of the water from the machine but it does not spin the clothes dry?Is this correct?Also does the mahine only show the lid lock icon when the machine is beeping?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a hotpoint aquarius WF32O and when i put
is it spinning and craccleking,,carbons faulty in motor ;;will work on spin but not lower voltage wash?
change carbons,, use genuines,only
Jun 21, 2010 | Washing Machines
Whirlpool washing machine
You could have a hole in the pump. Check to see where the water is coming from after removing the cabinet, or tip the machine back.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
133 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
