Where can I get discontinued valve 30810025-Ferroli ?
2 Suggested Answers
  • 9 Answers
SOURCE: where can I find a Ball isolating valve for a
Ferroli Limted is you best bet phone number 00448715592920
Posted on May 04, 2010
How do I set the heating timer on a Ferroli Modena 32C HE boiler?
I did a Yahoo search for "set heating timer on Ferroli Modena 32c HE boiler" and got this -
http://www.ferroli.co.uk/brochures/Timer-HE-013001X0-Instructions.pdf
If you can get to that site, it will let you download a PDF which seems to answer your question.
I copy/pasted the hyperlink, but you may have to enter is yourself. My last hyperlinks did not work.
Sep 12, 2017 | Heating & Cooling
Ferroli boiler
You should have 12psi for boiler to operate properly. Sounds like first you have a leak in your sytem. Second sounds like pressure reducing valve is not working properly.
Dec 19, 2013 | Plumbing
Fault code f26 ferroli optimax 25c how to reset
There is a parameter on the pcb to change would take 30seconds to do. Never replace ur pcb for these faults. Hold down reset untill u see t5 press reset 1 more time it will then say p01 press the heating temp button until u see p02 press the hot water temp button until it changes to numberv2 and that will fix ur problem
Dec 25, 2010 | Heating & Cooling
Ferroli optimax he 31c. brand new system will only heat 3 of 8 rads. boiler on 90c will only burn for 15sec then D2 shows and it cuts out. Why??
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
solution GET RID OF THE FERROLI
Dec 22, 2010 | Heating & Cooling
Why does my Ferroli HE31C keep switching off code A3.
Here you go, page 30, sounds like it's overheating, possibly a problem with the boiler stat or lack of circulation in the system. http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Apr 06, 2010 | Water Heaters
Need the code to work universal remote with airconditioner
usually there is a way to scroll through the remote to find your component. check through your manual to see what sequance you have to use
Feb 19, 2009 | Honeywell Programmable Thermostat Heater
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
