Question about DBX Drive Rack 4800
I have bought a dbx 4800 ,it worked well for few months.Now i have a problem when i switch it on it turns off after 3 minutes .what could be the problem ?
  • Alex brandgen
    Alex brandgen Feb 10, 2014
    hi i think that the problem lies in the firmware or Eproms have you updated the unit ? in case the answer is yes ,then the problem lies in the Eproms
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 232 Answers
Bad power supply
Posted on Sep 20, 2014
Toshiba 62hm15a blows lamp after 3months
One possible reason I can think of here is I think this model had a quick start or quick on feature.
What will happen if it does is set will come on and work normally--when you turn it off and watch the lamp, it will dim down but NOT GO OUT--AFTER 3-5 MINUTES THE FAN WILL (LAMP FAN) go off.
It was a stupid feature, lamp is running 7/24 at about 40 percent brightness--idea was you did not have to wait the 10-15 seconds for brightness to come up and be normal when set is first turned on.
If this is your problem look in the main menu for a setting like that and disable or deselect it.
Set when cold will take longer to reach full brightness and when turned off lamp will go completely OFF and lamp fan will continue to run for a few minutes.
I hope this is your problem---PS if the set is real dusty inside it can cause issues but that is rare in this set.
May 25, 2012 | Toshiba TheaterWide 62HM94 62" Rear...
I have a sony Wega KDF 46e2000 and a couple of months a go it started going off and on by itself. And the local repair shop said we needed a new bulb it was going bad. So we bought one a month ago and I...
Three blinks is a lamp cover error. Make sure the lamp cover is back on securely and try again, there is a switch that does not allow the TV to turn on unless the lamp cover is on correctly.
If this does not work, then it means the lamp cover switch was damaged when you were putting the new bulb in and you need to get the switch repaired or get a new switch. They are two of them and cost about $15 each.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
PS2 Won't turn on!
try this:
1) turn off the PS2
2) unplug the PS2 and wait a couple minutes before plugging back in.
3) turn on PS2
hope this helps :D
Aug 23, 2009 | Sony PlayStation 2 (PS2) Console
Ei210 in wall countdown timer in undocumented ''test mode''?
You could try disconnecting power to the switch for a few minutes maybe that will reset it. Other than that I would say cut your losses and replace it. Hope this helps a little.
Nov 12, 2008 | Intermatic EI210 Electronic Auto Shutoff...
My six month old Samsung fridge freezer stops freezing. But if I switch it off at the wall and wait a few minutes it works again. But then stops freezing again. So I switch it off at the wall for a few...
There is a possibility that you have a problem relating to the internal refrigeration system. It may contain moisture contamination which freezes in the refrigerant feeding device. Shutting it off allows the moisture to melt and restart the circulation of refrigerant. This problem can only be solved by a certified refrigeration technician.
Making sure the condenser is free of dust and dirt will improve the ability of the system filter/dryer to absorb and hold moisture.
Jun 03, 2008 | Samsung Refrigerators
Video problems with my westinghouse LTV 32 W 3 HD
This seems to be associated with the overheating of some component. On my set I need to check that the backlight is set to a low level. On reset it automatically adjusts to a level above maximum and the green screen will appear in a few minutes. I took the back off and that helped some.
Nov 27, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
DBX Drive Rack 4800 Logo
67 people viewed this question
Top DBX Audio Players & Recorders Experts
Philip Rowney
Philip Rowney
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
