The touchpad's left button is not working. the pointer works fine and so does the right click. I tried tapping on the on/off button on hte upper left side of the pad, reinstalling the drivers and made sure the synaptic pad was selected in the control panel but none of it works.
SOURCE: HP ProBook 4530s don't start. Lights blinking!!!
Sub out the ram one at a time, if luck is there unit will start, second option is remove the main battery often loads the system down.
SOURCE: turn off touch pad on hp probook 6550b
http://www.retrevo.com/support/HP-6550b-Laptops-manual/id/23720dj691/t/2/
This is the users guide for your model. John
SOURCE: Space bar is not working in my laptop..My laptop is HP ProBook 4530s
You should replace the keyboard. Either bring it in to a PC shop, or buy a replacement keyboard yourself and follow these instructions:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=5060880&prodTypeId=321957&objectID=c02907532
try to re configure BIOS setting the touchpad might turn off at bios configuration
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
