Question about dbx4800
Why does my dbx4800 rackdrive shut off after 3 minutes ?
I think that the unit has caught some trojan thru the program you used for update .
try to eliminate the virus by factory resetting then updating the unit again without failure
Posted on Feb 11, 2014
is the unit restarting again and again or just shuts off after 3 minutes ?
in case it restarts again and agian,then it seems that the unit is passing through a protection stage,and the unit needs some updating.
while if it shuts off and never turns on again then your problem lies with the power supply.
Posted on Feb 10, 2014
  • 3 more comments
  • Alex brandgen
    Alex brandgen Feb 10, 2014
    thank you dear alex for the answer
  • zcatharsis
    zcatharsis Feb 10, 2014
    But the problem is that the time is not sufficient to update the unit as it turns off after 3 minutes and then turns on ,,,,so what might be the solution for the little time we have to update
  • zcatharsis
    " unit will reset to corporate changes "
  • zcatharsis
    As you start the unit,after 3 minutes as it displays "unit will rest to corporate changes" it turns off
  • zcatharsis
    then restarts again and again
Heater runs for 2-3 minutes then quits
Either the unit is over heating and being thermally shut down or the temp shutdown switch is shutting down prematurely.
Jan 01, 2016 | Heating & Cooling
Ge adora dryer runs for 3 minutes and shuts off
Could be thermal fuse.... or control dial DW
Mar 20, 2014 | Dryers
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
Security alarm wont shut off
Make sure all doors are closed, Key out for 3 minutes.
If that doesn't fix it, Try a battery disconnect for 3 minutes.
let me know what happens.
Mar 15, 2014 | 2000 GMC Jimmy
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Gas and flame for 3 to 4 minutes then shut down
try cleaning of the flame sensor infront of the flame comes out. carefull its fragile
Jan 16, 2009 | Heating & Cooling
Hitachi 50UX22B projection ultravision. shutting off on its own.
Since the set seems to recover somewhat, Id look for poor sonnections first rather than defective components. If you can solder and arecomfortable working inside the set, you may be able to fix this yourself. Are there any other symptoms other than just shutting down? For example, blinking standby lights?
Dan
Jan 12, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
MITSUBISHI BIG SCREEN MODEL #VS55707
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
dbx4800 Logo
48 people viewed this question
Top DBX Audio Players & Recorders Experts
Philip Rowney
Philip Rowney
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
