Question about Alternative Engines Volume 3
Toyota corrollareg 2000 1332 liftback has 39000 miles only do not know if it is belt or chain does it need changing
Reg 2000
    Sergeant:
  • 406 Answers
I would say no and most likely it is a rubber belt...and most cars now can go over 100,000 miles not a problem but it depends on the driving style jack rabbit driving may need quicker attention of 50,000 miles or so.. but check your owners manual and you know your driving style...good luck.
Posted on Oct 03, 2014
Is there a recommended mileage for the replacement of the timing chain/belt for a 2.4 liter 16 valve 2004 Camry Toyota
It has a timing chain..Can't find any info on mileage to change?? belts are about 60.000 miles, i don't think you have to worry about changing by miles ??
You may call Toyota dealer and ask service manager?? Hope this helped you ?
Jun 28, 2011 | 2004 Toyota Camry
I just want to know,, 2006 toyota corolla having timer belt or chain?? if chain is having how often we have to check or change?
It will have a belt. Chains virtually never need attention, it is the belt that needs to be replaced every 50000 to 80000 miles.
Feb 11, 2011 | 2006 Toyota Corolla
Should i replace the timing chain on a 2004 corolla with 70000 miles.THANKS
chains are made to last for the life of the engine at 200k you might want to check the chain guides tha'ts all. you are thinking of the belts they had to be changed at about 80k.
Feb 07, 2010 | 2004 Toyota Corolla
Toyota 4runner timing belt or chain?
60000 or 48 months on belt which is used on the 5VZ-FE motor. The 2RZ-FE and 3RZFE are chain and there is no clear information about changeing them as a maintenence. i hope this helps.
Nov 12, 2009 | 1998 Toyota 4Runner
Timing belt
Hello shaukathn: The factory recommended service interval to replace the timing belt. Is 90,000 miles or 144841.2 kilometers. This is a belt and not a chain driven engine. Please rate the reply as this lets us know you received the correct information. Thank You for using FixYa. Roger
Apr 27, 2009 | 1998 Toyota Camry
Timing belt for a 2005 Toyota Corolla type S
Well you are in luck if that is your concern. The '05 Toyota Corolla has a chain instead of a belt. The recommended mileage I am not sure of but it will be listed in the owners manual. Most of the timing belts are recommended at no later than 90, 000 miles. The timing chains I have done I did because of a chain guide issue. They do get some slack in them but they aren't going to cause you to be broken down on the road with engine problems like a belt can.
i hope this helps, please remeber to rate this fix.
Feb 16, 2009 | 2005 Toyota Corolla
When to replace timing chain on 2003 Camry V6?
Replace the timing belt at 90,000 miles.
It will not damage the motor (bend the valves) if it breaks or jumps time
Finally, if you do change the belt, make sure that the water pump is inspected very close for any evidence of coolant seepage at the impeller shaft weep hole. If there is ANY evidence of wetness or leakage, replace the pump then. Easier to change the pump when the belt is off, than to have to do the whole job if the leak gets worse, and, if it leaks down the road, coolant on the timing belt will damage the belt, and you will have to buy a new belt, too. Change the plugs at 90 K miles, too.
Sep 16, 2008 | 2003 Toyota Camry
Does the Corolla 2003 model have a timming belt or chain?Does the water pump has to be changed at 70K miles? Thanks. Adrian
Adrian,
Until 2002 Toyota's had a timing belt. After 2002, Toyota's have a timing chain. Manufacturer/dealers recommend replacement of the timing chain at about 90,000 miles. I've talked to several mechanics - including the dealer - about the cost of changing out the chain. The lowest price I found from a very reputable mechanic is $260-270. He told me that if I brought in the part, he'd reduce the cost. The dealership was almost double!
Re: water pump: I haven't found anything that stated it must be changed at 70K miles. Hope this was helpful.
Lady V
Jul 21, 2008 | 2003 Toyota Corolla
1990 toyota tercel
Well it was'nt the timing belt! Turns out it's all in the fuel pump. If i turn the ignition to the on position for about 5 to 10 seconds before starting, it cranks right up.
Jun 09, 2008 | 1989 Toyota Tercel Liftback
Alternative Engines Volume 3 Logo
Top Pilotshop Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pilotshop Vehicle Part and Accessory Expert? Answer questions, earn points and help others
