Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
Delonghi esam5450 not producing coffee
Not coffee being produced. Getting error message "ground too fine adjust mill. How water?". Have followed instructions and turned the grind adjustment knob towards 7 but still no coffee being produced. Nothing at all coming from spouts. Have cleaned everything - including spouts. Help!!
4 Suggested Answers
SOURCE: have tried to make coffee, message comes up -
I had this problem and the spout was blocked you can push a small wire through the hole in the midle of the large white spout
Posted on Jan 23, 2010
EsWorld
  • 1618 Answers
SOURCE: We can't get any hot
Either the grind is too fine and the water cannot go through or the brew unit is blocked.
Posted on Apr 19, 2011
SOURCE: have a delonghi Prima Donna 6700 coffee machine and get this message
Hi there coffee person.
Have you tried disconnecting the machine from the power supply. As well as that check if there are enough coffee beans in the bean in the compartment and enough fresh water in the water tank. Not only this but is the compartment with the coffee "tablets" - full or empty. Fill or empty accordingly. Connect to power again, if the machine does not work the only advice have from here is "to clean the machine" as described in the manual or as you are used to.
Good luck
kolbrun
Posted on Mar 03, 2012
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Mar 19, 2017 | DeLonghi Coffee Makers & Espresso Machines
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Ground too fine adjust mill comes on about every other cup.
With any coffee grinder (especially those that are used for espresso) the burrs can wear down after a while. It seems like you've used this machine quite a bit and for various different types of coffees. If your machine is still covered by the manufacturer I would suggest contacting them about the problem or call your local specialty coffee shop. They normally have or know of a guy that can fix this rather simple problem for cheap. Happy brewing!
Sep 03, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
"less coffee" message comes up. Why?
It seems that for whatever reason not enough grounds are being produced to make the correct size puck of coffee for brewing. You need to investigate what quantity of grounds is being produced and find a way to increase it.
Oct 24, 2014 | DeLonghi Coffee Makers & Espresso Machines
I have a Delonghi EAM 3400 espresso machine. The problem I am having is that when I select an espresso very little comes out and it just drips instead of a full flow. It is also taking 4 minutes to brew...
It is likely that the coffee is ground too finely so if you turn the adjustment knob one click clockwise towards 7, while the coffee mill is working. Try clicking one click at the time until you are satisfied. Hope this works for you, Kolbrun
Nov 02, 2013 | DeLonghi EAM3400 Espresso Machine
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
43 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
