Fax--Error b 70 message on an Epson 3540
I received an "error b70" message on our Epson WF 3540. What is it telling me?
  • 24 Answers
SOURCE: Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Posted on Sep 25, 2007
Ajkill
  • 2035 Answers
SOURCE: Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Posted on Mar 11, 2008
SOURCE: comm error 232 & no fax detected when receiving
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Posted on Nov 18, 2008
POCBM
  • 121 Answers
SOURCE: Error message on my Hp Officejet J6480-Fax log full
Press the Setup button (c01361401.gif ).
  1. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  2. Press the Right arrow button (c01185072.jpg ) until Fax Log displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  4. Press the Cancel button (c01235250.gif ) to exit.
Hope this helps
Posted on Mar 11, 2009
cns assoc
  • 677 Answers
SOURCE: epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Posted on Feb 12, 2010
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
How to fix epson wf-3540 error code 0xFA all it tells me is to unplug then plug it in and still dose not work
Check the cartridges. Remove the cartridges and re insert it. sometimes bad contacts can causes such problems.
for more details check the link bellow
http://electro-medical.blogspot.com/
Dec 26, 2015 | Epson WorkForce WF-3540 Wireless...
Purchased the ciss ink system for my epson wf-3540. the ink tubing keeps getting pinched and the ink isn't flowing continuously.
I installed a CISS system in my WF-3640 which is very similar to the 3520. I just leave the top open and put a small piece of white eraser in the slot where the cover peg would go into. That way the printer thinks the top is closed. Yo can print, scan, copy, fax, etc., with the top open.
Oct 05, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
0x05 epson error code
What us the result of the error? what are you doing to produce the error?
Sounds, offhand, like a driver failure of some kind (ADF??)
Jul 19, 2015 | Epson WorkForceR WF-3540 All-in-One...
How do I reset wf 3540 printer to factory default to eliminate the driver updates software problems
Turn it off, if you can. Then unplug it from the wall and wait for it to shut itself down. Then plug it back in, wait, then push the start button.
It should have recycled itself.
Aug 15, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
What does error message 0xFA mean?
Anyone else looking, this error was a printer jam for me. Open the back, clear the jam. Power back on, all set.
May 27, 2014 | Epson WorkForce WF-3540 Network-Ready...
Epson error message 0x10
In the Properties toolbar of the device, access the Resources tab and select the device s resource and allocate it. When the resource chosen cannot be modified, access the Change in Settings and attempt to clear the Automatic Setting toolbar.Still having Problem Then follow Us For Epson Printer Support
Feb 16, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
I can't change the print quality in excel for my Epson WF 3540
A driver component is missing meaning not installed good or not all the drivers for printer is installed.
Jan 30, 2013 | Epson WorkForce WF-3540 All-in-One InkJet...
48 people viewed this question
jasbo
jasbo
