Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
HOW TO OPEN THE V188 TO CLEAN
I CAN'T OPEN THE Open hinged cover on bottom of heating unit for access to the heater surface for cleaning only
Is there a motor or fan that can be heard when pluged in?
Posted on Jan 02, 2016
2 Suggested Answers
  • 4736 Answers
SOURCE: Hi have a vicks warm
The easiest ans simplest way to clean it, is too mix a 50/50 solution of White Vinegar & Bottled Distilled Water (enough to fill the tank) and fill the the tank with the solution. Allow it to set for 30 minutes, then turn the unit ON. Allow it to run, until the tank is half empty. Pour out the remaining solution and fill with the Bottled Distilled Water Turn the unit ON and run until the tank is almost empty. Following these instruction will remove all the lime and calcium build up in the unit.
Tip: Using bottled Distilled Water rather than Tap Water, will totally eliminate calcium and lime buildup.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 13, 2011
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
How do I open the unit to clean the filter?
I have the scm630 and if you take out the water tank... On the very bottom is a little butterfly wing that you give a twist to and that releases the bottom of the tank to put in the filter. Just found that out my self. Kate
Oct 26, 2012 | Humidifiers
How to clean sunbeam humidifier swm5250
CLEANING AND MAINTENANCE INSTRUCTIONS (from the manual):
The following maintenance procedures must be routinely followed in order to ensure proper, efficient operation of your humidifier. The unit WILL NOT WORK CORRECTLY if it is not cleaned properly.
When the unit is in use, daily and weekly maintenance is recommended. Regular weekly cleaning prevents scale buildup on the heating element and base. It also prevents micro-organisms from growing on the base. This ensures that maximum efficiency will be achieved.
We cannot over-emphasize how essential proper cleaning is to the maintenance and continued use of your unit and to the the avoidance of algae or bacteria build-up.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (O) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base and place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is cleaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element clean with a soft cloth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier. DO NOT use any metal or hard objects to clean the Heating Element. Never use detergents, gasoline, kerosene, glass cleaner, furniture polish, paint thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the tray by partially filling the base with one 8 oz. cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a cloth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
Disinfect Tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet all surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until the bleach smell is gone. Dry with a clean cloth of paper towel.
4. Refill the water tank with cool water; replace the housing and water tank. Repeal ALL Operating Instructions.
Jan 22, 2012 | Sunbeam Humidifiers
Hi have a vicks warm steam vaporizer model v188. works great, just wanting to clean it. Can't find my manual anywhere.
Aug 13, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
The Hygrometer on my Air-O-Swiss U7142 reads 25% all the time. I assume its not functioning properly as I have other hygrometers in the house which say higher readings. Is there a known way to fix this? I...
I have got the same problem with my u7142 unit. This most probably means that the hygrostat inside is either broken or it has been heavily covered with the "white dust" in case the demineralization cartridge has not been changed for a long while.
To resolve it you have two options: either clean the humidity sensor or replace it. The sensor is at the bottom of the front panel, so you need to disassemble the front panel only, no need to open the whole unit (note that there are 2 screws at the bottom holding the front panel also). You need to get the sensor out from the printed circuit to open the cover and clean the surface of the sensor with something (blowing air does not help; you need physically touch the surface with something). If it does not help then you can go for the second option to replace the sensor, the type used in the unit is SYH-1. It is not a pricy element so you may go straight to the replacement if you find a shop nearby to buy it. I have simply replaced the sensor and now the unit is showing the proper humidity value and adjusting the steam automatically again.
Mar 03, 2011 | Air-O-Swiss U7142 Humidifier
How do I clean / sanitize my sunbeam humidifier swm5250 with bleach?
I'm no expert, but a friend of mine loaned me her humidifier recently and she just put some bleach and water in the tank and cleaned the tank with that. It did leave a smell of bleach in the tank that could be smelled any time it ran, but after a few refillings, it went away, and I figure if it smells there must be a little left, which means it should clean the working parts fairly well too. (while you're running it the first few times) And the medicine tray in the SWM5250 is dishwasher safe, so I would just run that through the dishwasher, but bleach should be fine for that too.
Jan 27, 2011 | Sunbeam Humidifiers
I used to see mist coming out of the humidifer. Just set up for this year, changed the filter, etc. and there's no mist coming out. Is this ok?
No you probably have scale around the heater thus not heating the water warm eneough. The water trough is located in the bottom of the unit and it gets covered with scale you can sometimes crumble it off with your fingers. Sometimes you have to use a cleaner on them too. Me personally on mine I clean it with a flat blade. I have cleaned mine twice this year as I have hard water
Dec 13, 2010 | Vicks Cool Mist V3500 Humidifier
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Dec 19, 2009 | Sunbeam Health at Home Warm Mist...
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Aprilaire 600 doesn't seem to be running at all
check list
1.check the clamp on the pipe where water line connects
is the hole clogged (water turned off)wont take long
2.Is water flowing all the way to resevoir after turnnig water on
loosen line at reservoir
3.jiggle float water should enter the reservoir inlet to float valevel
somestime cake up,clean float off
4.Remove pump cap clean impeller and standpipe
5.clean reservoir,and close everything up
Usually the hole in the pipe is clogged up in step 1 or the float is sticking if there is no evidence of water in the reservoir
Nov 20, 2007 | Aprilaire 600 Humidifier
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
336 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
