Question about Garden
How do i change the auger drive belt on a Craftsman 3/20 ES snowblower
    Master:
  • 755 Answers
Look on youtube
Posted on Feb 03, 2015
Snowblower....auger takes time to get going...like five minutes...it will struggle to start spinning then eventually warms up and is fine....whats the issue?
It is most likely your auger drive belts. There are two of them, and they need to be replaced periodically. Your manual should describe in detail as to how to replace the belts. Always start by removing the spark plug wire.
Improper gearcase lubricant could also cause problems. Your manual should tell you specifically what to use in the gearcase, and how to fill it. Also look for grease fittings on the auger and use a low-temp grease to service those fittings.
Lastly; behind the auger is the impeller shaft. Reach in and see if it wiggles. If it does, then have your impeller bearing replaced.
Feb 13, 2015 | Craftsman Snow Blower / Snowblower Bottom...
What are the belt sizes for a craftsman snowblower model# C950-52379-5
Based on the following info from SearsPartsDirect.
Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Feb 09, 2015 | Craftsman Garden
What is the number of the auger belt on a Craftsman snowblower model number 71-52408-4
Try to google or go directly to Sears online support. If your product is still being made, go to the new purchase page, see if the details tell you, if not, check out the reviews to see if anyone else knows or has asked for the part number.
Or just go to sears online support, it might tell you.
Tip- I got a washing machine replacement belt online at ebay for only a couple of bucks, while the company wanted like $30 or so for the same thing.
Sep 18, 2014 | Sears Parts Direct Auger Drive Belt -...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Snowblower stalls without reason and now makes a squeeling noise. craftsman 8.5 hp model 536.891851
Check the drive belts at the engine for wear or damage. It could also be a bad bearing at some point in the auger/impeller or wheel drive. Try to pinpoint the source of the noise and what you do that makes it squeal. Good luck!
Jan 22, 2011 | Craftsman Garden
How to remove the belt from craftsman snowblower model C459 52560 MFG code 1/055/3-0079
Unfortunately like many other snowblowers you first need to seperate the auger/blower assembly from the drive/engine assmbly. Pretty straight forward after that. Make sure you put belts on the right side of the metal tab that cleans the back side of the belts when running or you'll they'll cut in two the first time you engage the auger
Dec 17, 2010 | Kitchen Ranges
How to change drive belt-Ariens 522 snowblower-model # 938017
Which belt? You are referring to the auger drive right? The self propell uses a friction disc drive.
The auger drive has two belts, and in order to replace them you need to seperate the auger from the engine (split) the blower.
Happy days.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 13, 2010 | Garden
How do i change the auger belt on a honda hs 70 snowblower?
Remove the auger belt housing cover 4 bolts (10mm), if you are lucky, you can take the belt out, or just cut it. The slide the new belt between the auger and driving pulleys. there is a break pad under the auger pulley, so have someone engage the auger handle and put the new belt on the auger pulley. Or you can remove 10 12mm bolts and separate the auger and engine. Even though you have remove more bolts, it is easier.
Nov 26, 2010 | Garden
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
