Televison & Video Logo
A
Anonymous Posted on Feb 10, 2014
Alba tv AELKDVD1988
Unable to retune in any programmes.Aerial connections checked OK,After trying manufactuors reinstallation instructions.
5 Related Answers
Anonymous
  • 77 Answers
  • Posted on Jan 06, 2008
SOURCE: PS2
By an aerial do you mean a converter?
For the neew TV's you don't need one. Just plug it in using A/V cable (yellow is video, red and white are audio). Be sure you take note of which input you are plugging it into on the TV, and then use your TV's remote to change the video input (usually will be labeled video or TV/Video on the remote) to the one you plugged the PS2 into.
Anonymous
  • Posted on Nov 03, 2008
SOURCE: alba portable tv tuning set up?
its stuck on the same channel it says red gain at top of screen its not responding to remote control
Anonymous
  • 4 Answers
  • Posted on Aug 23, 2009
SOURCE: unable to connect o any programmes or internet,
Do you have a firewall installed? Check it's settings and make sure the settings allow connection to the internet.
Anonymous
  • 66 Answers
  • Posted on Oct 17, 2009
SOURCE: We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
Anonymous
  • 3006 Answers
  • Posted on Oct 20, 2009
SOURCE: No programme info ona Sony TV after the Freeview retune
Unfortunately you haven't said which exact model of Sony tv you have, but there were a lot of their models which didn't behave correctly after the digital retune. In most cases this led to a digital tv freeze.
The official advice is to first try the retune again; from experience I'd add that you need to try it at least twice and to do so at different times of the day in case there is temporary unplanned signal disruption or other environmental factors.
If that does not work then you need to contact Sony directly for advice on 0870 511 1999.
Please cut and paste the following web address into your browser and you'll see a list of Freeview equipment which is known to have incompatibilities with the retune (you need to have Adobe Reader installed). Unfortunately the list has proven to be somewhat less than comprehensive.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my advice to be of assistance and in return ask only that you remember to rate my answer.
1helpful
Purchased 43U6763DBB tv yesterday. Gone through all setup instructions, selected analogue aerial but unable to get any programmes. This aerial works ok with other TVs. Can you help?
Some sets have more than one input for signal. Make sure that you are using the correct one of OTA transmissions.
If still not working return set since it is apparently defective.
2answers
Why won't my tv connect to anything? Had no picture or sound, it says No Sync. Signal.
Assuming the television is OK and you have selected the correct 'SOURCE' then check you aerial connection and retune the set. If this does not work, take the set to a friends house and try in a 'known good' location. Download the user manual and use Dr Google for hints and tips to FAQ's. Cheers
MY ALBA TV SAYS NO SIGNAL EACH TIME i PLUG IT IN
Either the TV has lost its memory and just needs retuning; or your coax and/or aerial is stuffed.
2answers
Is it possible to enter the service menu on alba aelkdvd1988 portable tv i'm trying to see if i can get the usb port to read a flash drive with movies on
you can see in the menu the video support read by the player. also in the front panel of the unit their is a tag what format can accept like divx or mpeg etc.
Picture and sound break up on ITV3.
You'll need to tell us what TV, set top box you have for us to help. In the meantime, check your aerial connections to make sure they are secure and try a retune after that. Often, doing a retune without the aerial connected, then a full retune with it connected does the trick; this 'flushes' old channel settings in some equipment. In my area, ITV3 is a bit iffy and I cured my problem by checking all my coax connections up to and including booster and aerial.
2helpful
After having to retune my Alba Freeview Digital Top Box - Model No. A002157058939 - on September 30th to allow for better digital reception of Channel 5, I am no longer able to receive ITV3. Have retuned...
You may need a better aerial. Digital TV signals need good signals or you can't pick up the full range of channels. Broadcasters and others are tending to keep their mouths shut about the expense of needing much better things on the roof than what many people use to get away with on analog signals. Even if you have a good aerial, If you have the 'brown' coax cable connected to it you could lose signal and stations. So it's best to replace it with Satellite coax cable FT100. That should stop a lot of blocking caused by interfearance by cars or those off road bikes youths ride around on.
Unable to retune in tv programmes. dvd part of tv
make sure your aerial is connected and if connected its not broken
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
