Question about NetGear Computers & Internet
My siemens repeater does not detect my netgear router
  • stephen Adams Mar 08, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What siemens repeater, What netgear router. How far away are they?
    Sergeant:
    Champion:
  • 324 Answers
Check the security key settings.
Posted on Mar 11, 2015
Using router as repeater
Make sure your router supports repeating, check the manual for your device or google "NetGear WNR1000 Router Repeating".
Nov 13, 2013 | NetGear WNR1000 Router
Netgear 3300 does it work as a wireless repeater?
http://reviews.cnet.com/routers/netgear-wndr3300-rangemax-dual/4505-3319_7-32863752.html
sounds like that router isn't really well liked.
I do not recommend using wireless repeaters because your "second" network is only as good as the uplink to it, and I find you often can't move the repeater too far from the first router without sacraficing a lot of quality.
plus that router has bad range to start from what I hear
Oct 14, 2012 | NetGear WNDR3300 - RangeMax Dual Band...
Can a netgear router be used as a repeater?
Yes it can ,if you are open to third party software it is quite simple using DD-wrt software ,they have great how to do step by step solutions or you can just view their wiki .
Dec 25, 2011 | NetGear WGR614 54Mbps Wireless Router...
One of my friend in my neighborhood using netgear wifi router when i connect with that performance vise netgear seems 2 b better is thr any setting to enhance the performance .... we both r using airtel...
To enhance performance is to enhance signal strength which can be accomplished with a repeater or an ACCESS POINT router with detachable antenna.
THen you can connect an omnidirection or bidirectional antenna which will enhance the signal.
You can check TP-Link products. Their routers are with detachable antenna. They have a grid antenna which is like a bid dish for detecting signals.
God Bless You!
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access...
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Oct 26, 2009 | NetGear DG834G Router
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Siemens SpeedStream 2614 Router
Updates for this model were probably discontinued some time ago. For basic routing functions, you don't really need to upgrade. If you want this router to provide some basic firewall functions to protect against hackers on the Internet, it would be best to upgrade to one of the inexpensive LinkSys, Netgear, or D-Link routers that have improved firewall capability.
Jan 05, 2008 | Siemens SpeedStream 2614 Router (ss2614)
Wireless adapter ......need something compatible with a siemens router
you probably need another router such as linksys, netgear, belkin.. etc.
Nov 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
