Question about Garden
Noma Snowthrower D2450010 auger doesnt stop spinning when disengaged
I have a Noma D2450010 5hp Snow thrower. I replaced the V belt and noticed that the auger doesn't stop spinning when its disengaged. I noticed that there is an arm underneath the belt that is just laying there basically doing nothing. There is nothing attached to it, so it seems it doesn't serve a purpose. When I look at the parts diagram on the sears website, the part looks to be The Brake Arm Rod. Could this be my problem. It also looks like there maybe should be a TENSION spring attached to this, which like I said thaere is nothing on mine right now.The only stopping the belt right now are the two belt fingers. Can you tell me how to fix this and also should the Vbelt be under this arm or over it
  • Garden Master
  • 2,478 Answers
Idle pulleys go on top of v-belt.
Posted on Feb 10, 2014
5 Suggested Answers
  • 1114 Answers
SOURCE: i have tension spring that is disconected inside a toro 824 snowb
That spring will attach itself to just about anything available. So put some hand tension on the idler pulley of the tensioner, and make an arc with the end of the spring, and there should a tab or bolt or post that the spring could attach to.
Posted on Aug 24, 2009
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
nikhil120901
  • 38 Answers
SOURCE: I have a Noma snow thrower, Model : G2145000. Just put new blades on it. Doesn't seem to get all the snow, and some shoots out the bottom at the back. Is there a way to adjust these blades?
yes you will have to position blade in your own
Posted on Jan 21, 2012
I have a noma D2030070... with no owner manual.
Our two-cycle snow throwers use a 50:1 ratio of gasoline to 2-cycle oil. A 50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil with 1 gallon of gasoline. NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2 -cycle fuel ...
Feb 04, 2018 | Noma Garden
G2914000 manual
Try this site they have loads of Murray manuals listed. Murray took over Noma.. https://www.partsandservice.com/html/Murray/st
Dec 18, 2017 | Noma Garden
Change auger belt on noma snow blower
GO TO GOOLGE AND ASK THE QUESTION THIS WILL BRING YOU TO YOU TUBE AND THIS WIL SHOW YOU HOW TO REPLACE THE BELT
Feb 22, 2015 | Garden
Noma auger wont stop spinning when disengaged
Sounds like either the auger belt is jammed to tight or handle mechanism to engage/disengage is stuck in on position. I would remove belt cover to inspect auger belt and pulley first, then remove bottom cover and inspect auger engage apparatus. I think once you inspect the problem will be self explanatory. Good luck!
Feb 18, 2014 | Garden
Where is the auger sheer bolt
Figure 9 on Page 11 of the manual (linked below) shows the location of the auger shear pins. Do NOT substitute bolts for shear pins!
http://www.searspartsdirect.com/partsdirect/user-manuals/8227/536881800-Craftsman-Parts-SNOWTHROWER,+GAS-manual?pathRender=fromManualTabPage
Feb 11, 2013 | Craftsman Sears Snow Thrower Manual Model...
Need manual for Noma snow thrower D2045010
I would suggest taking a look at this Noma Snow Thrower Manual. Well I just noticed it isn't quite the right one, but maybe it will work?
Feb 03, 2013 | Garden
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE - RAISE REAR UP AND WHEELS DO - AUGER WORKS IT JUST WON'T MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Feb 02, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
