Question about Timex Watches
Is Timex Model W92 905-095025 NA waterproof - Timex Watches
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
Rubber gaskets for timex watches
The rubber gasket is the waterproof seal, to get the proper one you need to go to Timex or an approved repairer!
Nov 02, 2014 | Watches
After battery replacement, went in ocean and now screen is blank... Thinking the innards got wet, and are now fried... Thoughts?
Thanks for contacting FixYa
DId you do the battery replacement yourself or have a store do it for you?
Unless it is done by Timex, or a qualified Timex retailer, it will NOT be waterproof anymore as the seal has been destroyed.
You can try to see if Timex can still repair by going to this link
http://www.timex.com/info/Warranty
Best regards. Jewel
Sep 02, 2010 | Timex Sports Ironman Triathlon 100-Lap...
Is this watch water proof? Could I go for a swim timing myself would the watch be ok or would it destroy the watch?
mcdevito75 here, If your Timex is a quartz watch then NO, water will destroy your watch. If your Timex is a windup, it must say waterproof and even if it does, every 2 years it is adviseable to see a watch repair shop for up dateing the waterproof status of any watch. I would advise not to use your Timex in any large amount of water.
Aug 17, 2010 | Timex Expedition 40141 Wristwatch
Condensation on inside of face, how do I stop it from happening? and how did it get there in the first place? Watch is less than a year old, Timex indigo WR 30M
mcdevito75, Some watches are waterproof, shockproof, and so on. But, no watch is air proof, Believe it or not air is always in your watch and---all air contains water, hot air, cold air, Heat up air and you seperate the water, the air in your watch gets hot on your wrist then cools when you go outside or when you take off the watch. The condensation you see is the tempersture change of the air in your Timex, Believe it or not. It really can"t be stopped, If you can or have a small watch repir shop remove the back and put in another seal around the back cover this should help. Try to keep your watch at a constant temp.
Jul 03, 2010 | Timex 27191 Wristwatch
My Timex automatic gains a bit each day. Can I adjust it?
Most watches have some sort of adjustment but I would advise you to take it to a Timex dealer as removing the back can cause problems (particularly with the waterproofing seal).
Also, I could not see the back of the watch in the catalogue but many watches need special tools to remove the back.
Apr 10, 2010 | Timex Automatic #T2D931 Watch for Men
Need help setting interval timer on timex w-191-na 100 lap memory. need to set to 1 min and 2 min and repeat 10 times
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Popular T5E931 100 Lap Ironman...
I can't get the back on my watch after trying to install a new battery
good after noon ! if your watch is waterproof design you need a wrench opener,but if your watch is isnopin yuo need a knife to open that ,be verry careful to do that !thank you ! god bless !
Sep 03, 2008 | Timex Watches
Expedition Indiglo Waterproof 50m
how much is this worth my uncle gave it to me
Jan 17, 2008 | Timex Expedition 40141 Wristwatch
Watches Logo
642 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
