Question about Indesit W 123 Front Load Washer
Wi121 fills ok then trys to start drum is not turning dial gos round and flashs
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Check the belt if it's ok check the heater if its ok check the time of the water filling it should not exeed 3 to 5 minutes
Posted on Feb 10, 2014
2 Suggested Answers
  • 209 Answers
SOURCE: washing machine
this clicking of the timer tells you there is a fault somewhere, this could be anything, you have to check things i would do them in this order check the heater element, most common fault second the pump but you said that works then check the motor that drives the drum belt look at the motor control board for any signs of burning etc, this could indicate a motor fault you have not given much info, but with a fault like this thats all you can say, i have given you a brief starting point what and where to look, so happy hunting if i can be of further help get back to me
Posted on Oct 07, 2007
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
My becko wma150w washing machine fills and but the drum doesnt go round
Motor brushes need replacing. check belt tightness too
May 19, 2012 | Washing Machines
My bosch clasixx wont start fills and drains ok but just clicks
Possible motor brushes, worst case scenario..motor fault. Put the dial to off, hold the start button whilst turning selector one click left to 30 easy care, turn the dial to 40 cotton (without going thru the off ie all the way round anti clockwise) press start. This will activate the motor test, if you get two lights flashing separated by a led that is off this is a motor fault. (Not necessarily the motor complete, also will indicate loss of contact in the brushes). If it is a model with a display it may show F05. Happy hunting.
Nov 21, 2011 | Bosch Washing Machines
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Dial turning round, red light flashes 11 times
The timer must be replaced in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Washing Machines
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Jun 26, 2008 | Dryers
Broken machine
these machines are a pain. the dial is supposed to click round when there is a fault in a component such as the pump etc but in my experience it is just as likely to be the module. all you can do is to check the pump and heater and whatever else you think you can check and if all ok its the module. not worth repairing in my opinion
Apr 05, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
32 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
