Question about Epson Office Equipment & Supplies
Scanner error on switch on - Epson Office Equipment & Supplies
Hp laserjet m1522nf 52 scanner error
Step 1.Switch on the machine observe Optical scanner assm moving forward & reverse for checking home position? remove flat bed glass,clean it especially at black band area, fix it and check..Step 2. Switch off the machine, remove power cable, remove left side door,dis connect Scanner cable(connector J4) on formatter, switch on the machine, check if same error? replace formatter assm..if different error replace optical scanner(CCD) assm..
Sep 20, 2011 | HP LaserJet M1522n MultiFunction Printer
Error light on and saying scanner error
Hi!
Open the Lid for scanner, check for a switch on the side for Scanner Lock. Try to switch it to unlock position and retry booting up Printer. That should take care of scanner error message.
Hope this helps. Cheers!
Mar 04, 2011 | Epson Stylus CX3200 All-In-One InkJet...
My dr-x10c scanner gives an P007 error code i have tried cleaning the rollers but the error stills keeps coming back. do you think that it's time ireplace mty exchange roller kit???
Solution: I had the same error P007 on a Canon Scanner. Switched off the scanner, Opened the scanner. Located all of the sensors. Sprayed Platenclene spray and used a soft cloth and cotton buds to clean the sensors. Switched back on the scanner and the error was gone and its scanning perfectly. The error P007 is a result of dirty sensors!
Nov 19, 2010 | Canon Office Equipment & Supplies
2600 printer error 51023
51.20 Error
51.21 Error
51.22 Error
51.23 Error
The device has experienced an internal
hardware error.
51.20 Error-black scanner error
51.21 Error-cyan scanner error
51.22 Error-magenta scanner error
51.23 Error-yellow scanner error
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine.
Nov 12, 2010 | HP Color LaserJet 2600n Printer
Error no is 51.22
go to this link, and read page 12 .. your error is listed as
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
51.20 Error
51.21 Error
51.22 Error
51.23 Error
hardware error.
initialize.
device on.
Replace the engine
please post positive feedback for me
Oct 17, 2010 | HP Color LaserJet 2600n Printer
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Error message while switching on the scanner
sigo con el problema del escaner s2w 6400ut bloqueado me dice que siga la guia rapida para su desbloqueo
Apr 01, 2009 | BenQ Scan to Web 6400UT Flatbed Scanner
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
