Question about K?rcher Karcher Sc1020 Steam Cleaner
Karcher sc1020 one burst of steam then nothing
Lance will not produce steam
carl, Ithink your unit is clogged. Clean it thoroughly with vinegar or CLR And it should unclog. Rinse and fill up fresh water and power up! goodluck
Jan 31, 2014 | K?rcher Karcher Sc1020 Steam Cleaner
Leaking from bottom
Try checking for loose connection on hose
Aug 25, 2013 | K?rcher Karcher Sc1020 Steam Cleaner
Karcher sc 952 having problems with no steam coming out.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 04, 2013 | Karcher DE4002 Steam Vacuum
My shark floor steamer hesitates with steam then has a burst. What can I do?
Nothing, that's how it works...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
Steam cleaner smokes likes mad
the air fuel mix is not correct. the coil is blocking the air intake. fuel nozzle not pointing into the combustion chamber?
Dec 13, 2009 | Karcher Garden
Repair to old Karcher steam cleaner
q services settle north yorkshire.
01729825656
damian thats me
07970636222
Mar 13, 2008 | Karcher 2500 PSI Pressure Washer
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
K?rcher Karcher Sc1020 Steam Cleaner Logo
Top K?rcher Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a K?rcher Heating and Cooling Expert? Answer questions, earn points and help others
