Question about Aube TH144HPN2H1C Thermostat: Heat-Pump HVAC; Non-Prog
Restting thermostat after replacing battery
Touch screen not responding. Fan is on all the time.
Why is screen showing EE and will not respond to touch?
The replacement batteries could be defective or installed incorrectly. Also, the thermostat could have been reinstalled incorrectly after battery replacement.
Dec 22, 2015 | Honeywell VisionPRO 8000 Programmable...
I dropped my phone and the touch screen is no longer responding.
If the touch screen is not responding then you need to replace it. In market check whether the touch screen can be replaced separately it will be charge you less. Else you need to replace both the touch screen and display together which cost you more.
Feb 16, 2018 | LG Lucid VS840 4G Verizon
Touch screen stopped responding
Pull the thermostat face off the wall. Wait a few minutes, & gently line up the pins and place back on. Let display pull up. If that doesn't work, your thermostat is probably under warranty...Replace.
Dec 13, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Touch screen not responding on nokia c2-03
my nokia mobile c203 touch secreen not work
Jun 17, 2012 | Nokia C203
My buttons on my phone works but my touch screen is not responding to anything at all.
check MENU settings may be touchscreen is off ,else touchscreen loop is broken
Aug 02, 2010 | Cell Phones
ELo touch screens not responding to the touch?
is the screen worn? you might need to replace the touchscreen glass
Aug 31, 2009 | Elo 15" Touch Monitor
Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
Jul 30, 2008 | i-mate JAM Pocket PC
Aube TH144HPN2H1C Thermostat: Heat-Pump HVAC; Non-Prog Logo
Top Aube Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Aube Heating and Cooling Expert? Answer questions, earn points and help others
