Question about Panasonic Televison & Video
PANASONIC dvd RECORDER XW 390
NO FUNCTIONS AT ALL VIA REMOTE. AN ERROR CODE OF "D21' shows on the led screen. time is still displayed . have turned on and off replaced batteries in remote, still same issue. Does anyone know what this D21 code means please ?
4 Suggested Answers
SOURCE: panasonic dmres10 dvd recorder showing ' x hold '
This is the child lock feature, to stop unwanted use of the unit. Using your remote control, hold down 'enter' and 'return' until a message is displayed.
Posted on Jul 03, 2007
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Jul 25, 2009
On my Panasonic blu-Ray DMP-BD871 the screen says set 1 when I press the remote... Why is this happening I can get on to use my blu-Ray at all
Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players.
When you press a button and the display shows [ CHK REMOTE # ] or [ RC# ] or [ SET# ] it means that the DVD recorder and the remote control are not set to the same code.
To set the remote control code to that of the DVD recorder, press and hold [ ENTER ] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
May 24, 2014 | Televison & Video
Display shows RC 1 and I can not do any function. What do I do? jbourff@GMAIL.COM
The remote control and the main unit are using different codes. See page 78 of your user's manual (PDF download from the Panasonic support page.)
Oct 24, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Jan 22, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My panasonic dvd player and recorder is frozen will not function will not release disc or accept any commands DISPLAY SHOWS ??ERROR CODE U 99 RETAILER STATES I HAVE TO RETURN T O PANASONIC MOEL...
Yes, U99 is a software issue most of the times, you can check this website for the newests software version for your player:
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders
Try updating the firmware (software) on your player, if not you might need to send it for service to a Panasonic authorized service center.
Jun 23, 2008 | Televison & Video
Error code RC3
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Sep 12, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
