Question about HP LaserJet 9050 Printer
Grinding Noise in HP LaserJet 9050 printer? - HP LaserJet 9050 Printer
  • 4 Answers
SOURCE: hp laserjet makes a continuous screeching noise when plugged in and will not print.
I have an identical situation. I have isolated the source of the loud screech to the (laser scanner assembly) p/n RGO-1041. The unit is located underneath the top cover, where the printed paper rests after it is ejected. I had to remove the right and left side covers, then remove the three screws holding down the top cover. There are two screws up front and one to the rear, it then lifts straight up. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps. Sorry, I accidentally posted this in problem section.
Posted on Apr 04, 2008
aicaxz
  • 511 Answers
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
Posted on May 29, 2009
  • 56 Answers
SOURCE: HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Posted on Oct 09, 2009
  • 81 Answers
SOURCE: how to replace fuser drive assembly on HP laserjet
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
Posted on Jan 01, 2010
Pulkit558
  • 472 Answers
SOURCE: my hp laserjet 9050 displays
This is a motor lifter error for tray 2. Most times the issue is caused by a small spring which comes off the motor or the chasis where it attaches. See the attached page and look at item 3 as that is the spring. If it is ok, then you could try loosening the screw which secures the motor and then tighening it again. Do so with the tray removed.
Good Luck!
Posted on Sep 27, 2010
Hp laserjet 9050 prints blank pages
have you remove the sealing tape from toner
Mar 06, 2014 | HP LaserJet 9050 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
Change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
May 31, 2012 | HP LaserJet 9050 Printer
My hp laserjet 9050 show paper jam when the tray is empty
(1) dose it work ok when you install paper.
(2) when it runs out of paper it dose not a sheet going through it so it gives that code .If its still works dont worry about it should be fine.
Aug 13, 2010 | HP LaserJet 9050 Printer
Not fusing
Make sure the two blue levers are in the down position on the fuser. If the problem persist try another fuser .
Apr 03, 2009 | HP LaserJet 9050 Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Sleep Mode
Under the "RESETS" menu there is an option to "turn off" Sleep Mode.
Oct 14, 2008 | HP LaserJet 9050 Printer
HP LaserJet 9050 Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
