Question about Tivoli Audio Players & Recorders
My Tivoli PAL radio has lost its reception; stations I had always listened to are now all static. The PAL has not been mishandled or dropped...it just stopped receiving the stations.
My Tivoli PAL radio has lost its reception; stations I had always listened to are now nothing but static. The PAL has not been dropped or mishandled; it just stopped receiving. It is fully charged.
SOURCE: AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Posted on Oct 22, 2007
  • 161 Answers
SOURCE: no radio reception in office.
most portables have a very weak FM receiver, and a building interior tends to block a good deal of signals. your best bet is an old fashioned unit with a large retractable antenna.
Posted on Jun 12, 2009
TOLhamRadio
  • 509 Answers
SOURCE: antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Posted on Aug 21, 2009
BillB-SA
  • 2761 Answers
SOURCE: Tivoli Model One Radio Humming only, no reception
The fuse would cause a total absence of power. Your problem is likely a blown filter capacitor in the power supply. Unless you have electrical/electronic skills, the radio will require professional repair.
Posted on Oct 18, 2009
  • 3 Answers
SOURCE: AM/FM stereo receiver
Possible solution. I have fixed two with this problem. When the radio drops to a hard surface, the ferrite coil antenna is the heaviest component on circuit board. Look for cracks in solder or broken wires where attachments to circuit board occurs for this component. Use a fine point soldering iron with low heat.
Posted on Dec 20, 2009
I Lost FM on my Tivoli Model One. While FM was playing I touched the radio and gave it a static shock (very dry climate) and lost the FM. AM and Aux are fine.
It will need to go to a service centre for repair. Most probably the static electric jolt will have taken out either the FM RF amplifier of the FM mixer, meaning it needs component level repairs :o(
Sep 20, 2013 | Tivoli Kloss Model One AM/FM Radio
Tip
Tivoli PAL volume problems
I posted this tip elsewhere but the FixYa site is, shall we say, challenging.<br /> After years of use my Tivoli PAL started having volume problems. The audio began popping, volume changed erratically, static, booming, almost feedback sounds.<br /> In my case, and others as well, I've gleaned, the problem was the volume potentiometer. Apparently it oxidizes over time and the poor electrical contact is the reason for the erractic audio.<br /> I'm not an electrical repair kind of guy, so this isn't pretty.<br /> The volume and frequency controllers are secured to the knobs with metal collars. I pried the collars loose and got the horizontal board off, I sprayed Stabilant 22 into the volume pot. There are other electrical contact cleaners as well.<br /> Put it all back together. Let the flud dry. Good as new.<br /> Good luck.
on Apr 27, 2011 | Tivoli PAL Radio
Pal speaker
you should read the catalogue.
Mar 18, 2013 | Tivoli (PAL) AM/FM Radio
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Which radio stations are best to listen to your mp3 in the car?
That depends on where you are, and what frequencies the stations in your area are using. That's why you have so many choices. If you drive a couple of hundred miles away, you may find that you need to change stations.
Apr 19, 2010 | SanDisk Sansa e260 MP3 Player
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
I have a lot of static when i'm listening to AM radio on my bose radio
FM reception is good; however there is a lot of static on AM 1000. No problems on other AM stations. Any suggestions or than stop listening to "1000"?
Nov 24, 2009 | Bose Wave Radio
FM RADIO Reception
No, it should work, although it will depend on how good your reception is. This depends on how strong the signal is where you are trying to receive. If you have tried scanning for channels and all you receive is static, it's possible your tuner is bad. Have you tried to tune it to a known good station manusally?
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
Antenna on radio broke
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Open Questions:
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
